Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Rocker Team products > RIFFBOX
Old 02-27-2012, 12:58   #76 (permalink)
ttlin5188's Avatar
Member: 23253
S5PC100 cpu how to connect with direct memory plugin need help i try but showing error
Old 02-29-2012, 21:36   #77 (permalink)
legija's Avatar
Member: 256342
Sonork: 100.45940
  • Solved the problem with download of updates. Now no more nasty ‘Out of Disk Space’ error!!!Some users could experience this kind of error during download of large files (30MB and more). These errors were often with Wi-Fi configurations where certain routers dind’t handled passive ports FTP data transfers properly.
  • Added check if JTAG Manager is running with administrator rights (in case it is installed in Program Files location).
    This solves issues for older operating systems (Windows XP) which have no UAC and no manifest means controlling elevation of application rights. Thus – now if the JTAG Manager is started without administator rights it will restart itself with request to run it “as administrator”.
  • Embedded font for text message window on JTAG Read/Write page.
  • Improved displaying of DLL version information: If FileVersion info is available JTAG Manager will display it rather than the internal version supplied by DLL.
    This simplifies version tracking for us.
  • Download speed limit is increased to 250kb/s
Please click “Check for Updates” button in order to download and apply new updates.
The Following 5 Users Say Thank You to legija For This Useful Post:
Old 03-14-2012, 13:48   #78 (permalink)
legija's Avatar
Member: 256342
Sonork: 100.45940
Firmware 1.31
- APQ8060, MSM8260, MSM8660 (3rd generation Qualcomm chipsets) support is added.
- fixed ARM7 bug: exit from debug state into THUMB mode was corrupted.
- added after-halt "Emergency" script execution for ARM7 cores.
JTAG Manager 1.41
- fixed SettingsCode bug which was spawned after we've transfered to 12-digit wide 64-bit hex numbers representation.
The Following 6 Users Say Thank You to legija For This Useful Post:
Old 03-23-2012, 00:53   #79 (permalink)
Member: 215938
sorry for asking here, but google bring me here.
We are searching info over a new eMMC on XBOX360 console, and is great if this tool can help. Any suggestion is appreciate.
The eMMC is this PHISON Electronics Corp. Introduces the World's Best NAND Flash Solution
Old 04-24-2012, 19:18   #80 (permalink)
legija's Avatar
Member: 256342
Sonork: 100.45940
JTAG Manager 1.43
- added feature to use halt mode from a DLL rather than to use a default one.
- added "DCC Loader USB Interface" feature. If selected resurrector (DCC Loader) supports USB communication
(RIFF BOX DCCLoader USB Interface Port appears in windows devices list)
then, after DCC Loader is started, the JTAG Manager will switch further communication with DCC Loader to the USB port
thus data exchange speed will increase.
Please note, to use this feature you need to attach USB cable from device to the PC USB port,
and install drivers for "RIFF BOX DCCLoader USB Interface Port" on first use.
DCC Loader USB Interface is not used during resurrection operations (Resurrection page, Resurrect button).
The Following 4 Users Say Thank You to legija For This Useful Post:
Old 08-31-2012, 16:25   #81 (permalink)
legija's Avatar
Member: 256342
Sonork: 100.45940
31.08.2012 :
eMMC Partition Table FullFlash Image Files Processing Plugin (eMMCDiskPartitions.dll) v1.01
- Addded FLY partitions names to the list (based on Fly IQ285).
Old 10-18-2012, 14:03   #82 (permalink)
legija's Avatar
Member: 256342
Sonork: 100.45940
18.10.2012 JTAG Manager 1.45
- ST-Ericsson NovaThor U8500 MCU support is added;
- Updates List is now displayed in alphabetic order ("Check Updates" button on the "Box Service" page);
- small cosmetic change to CTRL+F find form: CTRL+V/CTRL+X operations on ID search field starts search immediately;
- added "Override Embedded Reset Strategy" feature: is usefull in rare cases when there are some problems with target
coming out of reset, etc. The feature is accessible via "Advanced Settings" button on the "Box Service" page;
- added "Apply NRST before connecting to target" (to setup click "Advanced Settings" button on the "Box Service" page);
This feature is handy for development purposes especially when working with Qualcomm MCUs - after erroneous H/W config
(most often is 0x45 error code) MSM locks down, to reconnect need to reset power. Enabling this feature simplifies this.
Firmware 1.34
The Following 35 Users Say Thank You to legija For This Useful Post:
Old 11-16-2012, 16:40   #83 (permalink)
legija's Avatar
Member: 256342
Sonork: 100.45940
JTAG Manager 1.46
- Added IDCODE analize and displaying known MCUs for that IDCODE.
Click Analize JTAG Chain to see.
- Added IDCODE API for DLLs;
- Extended DCC Loaders Read/Write functionality to have separate buffers for read/write;
The Following 9 Users Say Thank You to legija For This Useful Post:
Old 11-19-2012, 13:43   #84 (permalink)
legija's Avatar
Member: 256342
Sonork: 100.45940
JTAG Manager 1.47
- Added new more APIs for Resurrector DLLs. These allow more flexible target initialization;
- Added "PAUSE" feature which allows now JTAG Manager to work be "paused" on command from Remote Helper.
Paused JTAG Manager frees RIFFBOX comport and becomes inaccessible until Remote Helper allows it to "unpause"
Thus, Remote Helper may work without fear that user may meddle in process.
Old 11-28-2012, 18:16   #85 (permalink)
legija's Avatar
Member: 256342
Sonork: 100.45940
JTAG Manager 1.48
- Added checking of plugin version before activation of it.
- Nothing else is changed. New version of compiler used requires to update to 1.48
Please note, with older versions you will not be able to use plugins. Re-download all plugins again from support.
The Following 8 Users Say Thank You to legija For This Useful Post:
Old 04-24-2013, 18:44   #86 (permalink)
legija's Avatar
Member: 256342
Sonork: 100.45940
24.04.2013 RIFF JTAG - RIFF JTAG Manager v1.49, RIFF Box Firmware v1.35 released (Cortex-A15, Cortex-A5)
Whats new:
  • Added support for Cortex-A15 and Cortex-A5 cores.
  • Fixed emergency script issue for multi-cored Cortex MCUs: it was executed after first core was halted.
Now it is executed after all core(s) (if specified by reset strategy) are processed (halted).
  • New Popup balloon is added with hints about 'Dead Body ID is wrong' error.
  • Added Windows 8 support.
  • Added "RIFFBOX on the Network" button (BOX Service Page).
    User can easily visit some main RIFFBOX's internet locations.
  • Some new IDCODES added to the search engine (CTRL+F)
The Following 132 Users Say Thank You to legija For This Useful Post:
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
DES key Driver black Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 07-19-2012 05:32
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-19-1999 17:41
Page generated in 5.43671 seconds with 13 queries
