04-12-2011, 10:51 | #31 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 |
The Following User Says Thank You to legija For This Useful Post: |
04-20-2011, 16:33 | #32 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 20.04.2011 JTAG Manager v1.31, RIFF Box Firmware v1.23 released Whats new : JTAG Manager 1.31
Firmware 1.23
Please click “Check For Updates” button in order to download and apply new files. Closing all running application before starting update process is recommended. |
The Following 6 Users Say Thank You to legija For This Useful Post: |
04-21-2011, 18:49 | #33 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 21.04.2011 JTAG Manager 1.32 released ---------------------------
The Following 3 Users Say Thank You to legija For This Useful Post: |
05-23-2011, 10:37 | #34 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Firmware 1.24 --------------------------- - The Most Annoying RIFF Bug (THE BUG) is Fixed Finally!!! During flashing operations both RIFFBOX and JTAG Manager were frozing while DATA LED was blinking constantly. |
The Following 16 Users Say Thank You to legija For This Useful Post: |
06-16-2011, 16:37 | #35 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Firmware 1.25 --------------------------- - added 5.0V USB Power On/Off controlling feature - changed sequence for 32-bit write accesses for ARM11 core (MSM8xxx support) JTAG Manager 1.33 --------------------------- - Improved connection policy: Resurrection/DCC connection to device is implemented in such way that JTAG speed changes have 2 stages - booting stage and working stage. Booting stage is the one from the connection start and until the DCC Loader upload is complete. Booting TCK/RTCK speed are setup by JTAG Manager no matter what are the TCK settings by user (JTAG TCK Speed field in the JTAG Manager). Booting speed is hardcoded in the DLL. After "booting" stage is complete, the "working" speed is set - the one which is selected by user in the JTAG TCK Speed field. If Booting Speed in resurrector DLL is hardcoded as 'RTCK' the JTAG Manager would always use RTCK mode during booting stage. Now policy is changed that is when user selects a fixed TCK frequency the JTAG Manager will automatically change booting speed to the fixed TCK too. - fixed bug: if "Use End Address" and "AutoFull Flash Size" were checked there was error setting valid length to read. - for Advanced Users: advanced settings are now moved from the DCC Read/Write page ("Notifications...") into separate button on Box Service page (Advanced Settings button) - added 5.0V USB Power On/Off controlling feature For this go to Box Service page, click Advanced Settings: the Notifications dialog will be displayed, go to "Advanced Settings" page and set desired mode for "Enable 5.0V output" checkbox. When enabled, 5.0V power will be on after any "JTAG" operation executed and will remain "ON" until box restart or until "Enable 5.0V output" checkbox is unchecked and any "JTAG" operation is executed. - added optimization for flashing memory devices which are sector-based (like MDOC H3 or MMC/SD memory cards) - if error code 0x3C (write-protect) is received no recover attempts are made. |
The Following 12 Users Say Thank You to legija For This Useful Post: |
07-29-2011, 17:22 | #36 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 29.07.2011 JTAG Manager v1.34, RIFF Box firmware v1.26 – Cortex-A9 Dual core support added ! GDB Server v1.04 Whats new : RIFF JTAG Manager v1.34:
WARNING!!! Due to UNICODE migration old plugin DLLs are not compatible with JTAG Manager 1.34 Simply download new set of plugins which are unicode compatible now.
be available language selection. Following items are translated into selected language by the language DLL: 1. JTAG Manager interface – labels, captions, etc. 2. JTAG Manager messages which are shown during active operation. 3. Most of messages shown by resurrector DLLs 4. Some of Resurrection Manuals (if current version of language pack does not have translated version of Resurrection Manual, then an original, English version will be shown)
Thus, for example instruction: &Resp=data.long(APB:0×12345678) – will read dword from APB bus at address 0×12345678
b) after JTAG Manager exe restart
UNEXPERIENED USERS PLEASE NOTE: For example 8 digit hex value 0×12345678 entered into 10 digit field IS NOT 0×1234567800 (!!!!!) CORRECT IS 0×0012345678
For example, if target has 4 cores (Quad-core MCU), then after HALT operation only Core0 is halted. To halt Core2 user has to write script: CORE.SELECT 2 BREAK For example, to run Core3 user has to write script: CORE.SELECT 3 GO
08-04-2011, 12:08 | #37 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 04.08.2011 JTAG Manager v1.35 released Whats new :
Though, end-user may benefit from this too: Use “Settings Code” string for JTAG Manager to automatically setup all DCC Read/Write settings
Now available disk space checks are performed prior disk write operations. Please click “Check For Updates” button in order to download and apply new files. Closing all running application before starting update process is recommended. |
The Following 9 Users Say Thank You to legija For This Useful Post: |
10-06-2011, 12:29 | #38 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | JTAG Manager 1.36 --------------------------- - added fast presets for automatic selection of settings for most common operations on DCC Read/Write page For this click Settings by Code button and select a desired preset from list and then click Apply Settings. For example if user selects "Write Full Image into NAND memory" the valid settings on the DCC Read/Write page for writting full images into devices with NAND memory will be automatically selected - fixed serious bug which caused resurrector DLLs which do upload data into RAM to upload broken data For example DLLs which start Downlad Mode directly use this feature. - added feature to accept text name of memory chip from DCC Loader and display it (currently used to display eMMC memory product name) - fixed bug for resumming interrupted DCC Read: ifvcurrently cached file size was greater than > 2GB (that is if read was interrupted on point when there was already more than 2GB of data read) the new reading data was not appended to the readout file end, but instead the file was corrupted. - fixed bug for saving big files (after reading on DCC Read/Write page): if size exceeded 0x7FFFFFFF bytes JTAG Manager show no free disk space error. - added TEGRA2 chipset selection in the Target list - fixed an issue with the resurrection progress bar: in some cases during resurrection operations the progress bar would always stay at 0%. Firmware 1.27 --------------------------- - added TEGRA2 debugging support (dual-core Cortex-A9) - added new breakpoint type: "address mismatch" which allows geniune single-stepping on Cortex-A8,A9 (CoreSight) targets (thus GDB Server can now perform low-level single step commands) |
The Following 19 Users Say Thank You to legija For This Useful Post: |
11-11-2011, 16:11 | #39 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | JTAG Manager 1.37 --------------------------- - fixed bug which caused not to report improper firmware version of riff box - (SDK): more functions are now available (exported) for future Resurrector DLLs; Firmware 1.28 --------------------------- - added few more H/W script (*.has) instructions; - added some security extensions for Xperia repair; |
11-19-2011, 12:28 | #40 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 19.11.2011 - QUALCOMM MDM6600 NAND Generic DLL released Whats new:
12-16-2011, 13:32 | #41 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | RIFF JTAG - Direct Access Plugin 1.03 -World First! APQ8060, MSM8260, MSM8660 ! ! !
Please check here for more details. 16.12.2011 Direct JTAG Access to Flash Memory Plugin v1.00 Release info: This plugin performs direct access to a flash memory used in the selected target. No DCC Loader is used here, thus it is completely independent of target hardware implementation (RAM memory availability, visibility, addressing and layout, core clocking, etc.). Main disadvantage is a noticeable data exchange speed decrease comparing to the DCC Loader’s data exchange speeds (approximately 10...20 times slower). With the help of this plugin you can do:
Currently supported memory controllers are:
Currently supported chipsets and cores for JTAG I/O operations:
Memory reading/programming logic is almost same as is performed on the DCC Read/Write page in the JTAG Manager - Main and Spare fields, Auto FullFlash size detection, ability to flash image files (for NAND)., etc. Users familiar with the DCC Read/Write page features will not be required to learn almost anything new in order to be able to use this plugin. Thus it means data files read from memory by this plugin (partial or full flash image) can be flashed back through the DCC Read/Write page, and vice versa. Here, it is user’s task now to know such info about target as what exact MCU is used in current device, what memory is used (NAND, OneNAND, NOR, eMMC/SD, MDOC or other), which component of target system can see this memory (for example NAND memory is usually visible to MCU’s Embedded Memory Controller, while NOR is directly accessible by the MCU itself; OneNAND memory in most cases is directly accessible by MCU but sometimes it can be visible via MCU’s Embedded Memory Controller). Please note main differences with the DCC Read/Write methods:
Most common errors which can happen during direct read/write operations:
Important info: TEGRA 2 can be connected via CORTEX or ARM7 cores. In some cases, where CORTEX core is in sleep mode, it’s only possible to access ARM7 core, thus allowing access to shared memory space. Restoring Boot partitions via ARM7 core will enable access to CORTEX core after power reset. Sample: Last edited by legija; 02-25-2012 at 16:51. |
The Following 84 Users Say Thank You to legija For This Useful Post: |
12-16-2011, 14:17 | #42 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Guys, please keep this thread CLEAN for useless posts. It should be used for precise and specific questions related ONLY to use of this plugin. Thank You. Last edited by legija; 12-16-2011 at 15:04. |
The Following 14 Users Say Thank You to legija For This Useful Post: |
12-16-2011, 15:18 | #44 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | i just want to ask if this update is supported for dead MF180 ? i have one which is dead, maining even i connect to usb does no reaction happen, this history is happen after i flash the wrong firmware, i just make as a trial because i ask in support regarding this isue but no body can know. i dont know if they know r may be they are busy, or is just ignore , well this is the good update hope more models added, not by fixing some old supported phones and modems problems. |
12-17-2011, 00:14 | #45 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Mr.Legija please tell me about omap4430....... I can see omap4430 in Description Page... but i can't see in List....? not supported at this moment???? Currently supported chipsets and cores for JTAG I/O operations: "OMAP Family: OMAP1710, OMAP3430, OMAP3630, OMAP4430" |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
