Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 02-29-2012, 22:36   #76 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
  • Solved the problem with download of updates. Now no more nasty ‘Out of Disk Space’ error!!!Some users could experience this kind of error during download of large files (30MB and more). These errors were often with Wi-Fi configurations where certain routers dind’t handled passive ports FTP data transfers properly.
  • Added check if JTAG Manager is running with administrator rights (in case it is installed in Program Files location).
    This solves issues for older operating systems (Windows XP) which have no UAC and no manifest means controlling elevation of application rights. Thus – now if the JTAG Manager is started without administator rights it will restart itself with request to run it “as administrator”.
  • Embedded font for text message window on JTAG Read/Write page.
  • Improved displaying of DLL version information: If FileVersion info is available JTAG Manager will display it rather than the internal version supplied by DLL.
    This simplifies version tracking for us.
  • Download speed limit is increased to 250kb/s
Please click “Check for Updates” button in order to download and apply new updates.
The Following 5 Users Say Thank You to legija For This Useful Post:
Old 03-14-2012, 13:48   #77 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Firmware 1.31
- APQ8060, MSM8260, MSM8660 (3rd generation Qualcomm chipsets) support is added.
- fixed ARM7 bug: exit from debug state into THUMB mode was corrupted.
- added after-halt "Emergency" script execution for ARM7 cores.
JTAG Manager 1.41
- fixed SettingsCode bug which was spawned after we've transfered to 12-digit wide 64-bit hex numbers representation.
The Following 6 Users Say Thank You to legija For This Useful Post:
Old 04-24-2012, 19:18   #78 (permalink)
legija's Avatar
Member: 256342
Sonork: None
JTAG Manager 1.43
- added feature to use halt mode from a DLL rather than to use a default one.
- added "DCC Loader USB Interface" feature. If selected resurrector (DCC Loader) supports USB communication
(RIFF BOX DCCLoader USB Interface Port appears in windows devices list)
then, after DCC Loader is started, the JTAG Manager will switch further communication with DCC Loader to the USB port
thus data exchange speed will increase.
Please note, to use this feature you need to attach USB cable from device to the PC USB port,
and install drivers for "RIFF BOX DCCLoader USB Interface Port" on first use.
DCC Loader USB Interface is not used during resurrection operations (Resurrection page, Resurrect button).
The Following 4 Users Say Thank You to legija For This Useful Post:
Old 08-31-2012, 16:25   #79 (permalink)
legija's Avatar
Member: 256342
Sonork: None
31.08.2012 :
eMMC Partition Table FullFlash Image Files Processing Plugin (eMMCDiskPartitions.dll) v1.01
- Addded FLY partitions names to the list (based on Fly IQ285).
Old 10-18-2012, 14:03   #80 (permalink)
legija's Avatar
Member: 256342
Sonork: None
18.10.2012 JTAG Manager 1.45
- ST-Ericsson NovaThor U8500 MCU support is added;
- Updates List is now displayed in alphabetic order ("Check Updates" button on the "Box Service" page);
- small cosmetic change to CTRL+F find form: CTRL+V/CTRL+X operations on ID search field starts search immediately;
- added "Override Embedded Reset Strategy" feature: is usefull in rare cases when there are some problems with target
coming out of reset, etc. The feature is accessible via "Advanced Settings" button on the "Box Service" page;
- added "Apply NRST before connecting to target" (to setup click "Advanced Settings" button on the "Box Service" page);
This feature is handy for development purposes especially when working with Qualcomm MCUs - after erroneous H/W config
(most often is 0x45 error code) MSM locks down, to reconnect need to reset power. Enabling this feature simplifies this.
Firmware 1.34
The Following 35 Users Say Thank You to legija For This Useful Post:
Old 11-16-2012, 17:40   #81 (permalink)
legija's Avatar
Member: 256342
Sonork: None
JTAG Manager 1.46
- Added IDCODE analize and displaying known MCUs for that IDCODE.
Click Analize JTAG Chain to see.
- Added IDCODE API for DLLs;
- Extended DCC Loaders Read/Write functionality to have separate buffers for read/write;
The Following 9 Users Say Thank You to legija For This Useful Post:
Old 11-19-2012, 14:43   #82 (permalink)
legija's Avatar
Member: 256342
Sonork: None
JTAG Manager 1.47
- Added new more APIs for Resurrector DLLs. These allow more flexible target initialization;
- Added "PAUSE" feature which allows now JTAG Manager to work be "paused" on command from Remote Helper.
Paused JTAG Manager frees RIFFBOX comport and becomes inaccessible until Remote Helper allows it to "unpause"
Thus, Remote Helper may work without fear that user may meddle in process.
Old 11-28-2012, 19:16   #83 (permalink)
legija's Avatar
Member: 256342
Sonork: None
JTAG Manager 1.48
- Added checking of plugin version before activation of it.
- Nothing else is changed. New version of compiler used requires to update to 1.48
Please note, with older versions you will not be able to use plugins. Re-download all plugins again from support.
The Following 8 Users Say Thank You to legija For This Useful Post:
Old 04-24-2013, 18:44   #84 (permalink)
legija's Avatar
Member: 256342
Sonork: None
24.04.2013 RIFF JTAG - RIFF JTAG Manager v1.49, RIFF Box Firmware v1.35 released (Cortex-A15, Cortex-A5)
Whats new:
  • Added support for Cortex-A15 and Cortex-A5 cores.
  • Fixed emergency script issue for multi-cored Cortex MCUs: it was executed after first core was halted.
Now it is executed after all core(s) (if specified by reset strategy) are processed (halted).
  • New Popup balloon is added with hints about 'Dead Body ID is wrong' error.
  • Added Windows 8 support.
  • Added "RIFFBOX on the Network" button (BOX Service Page).
    User can easily visit some main RIFFBOX's internet locations.
  • Some new IDCODES added to the search engine (CTRL+F)
The Following 132 Users Say Thank You to legija For This Useful Post:
Old 08-02-2013, 15:25   #85 (permalink)
legija's Avatar
Member: 256342
Sonork: None
JTAG Manager 1.50
- Firmware update procedure is simplified now. To update box firmware
user now has to click single button, no other actions are required!!!
(in previous versions update firmware opration caused many questions from unexperienced users).
- Update server moved to new host. Thus, Check Updates for Updates button will now work correctly.
- Numlock key recognition is added so now additional keypad can be used
to enter digits 0..9 into decimal fields (like address/length fields)
The Following 33 Users Say Thank You to legija For This Useful Post:
Old 10-04-2013, 17:59   #86 (permalink)
legija's Avatar
Member: 256342
Sonork: None
JTAG Manager 1.54
- password recovery is available during firmware update too.
JTAG Manager 1.53
- added recovery password feature
- some few irrelevant improvements
JTAG Manager 1.52
- RIFFBOX Registration features enforced
JTAG Manager 1.51
- added RIFFBOX Registration features
- fixed few bugs related to Windows XP systems
- fixed bug which caused sometimes to popup Firmware Update dialog while box firmware is already up to date.
Old 11-02-2013, 14:17   #87 (permalink)
legija's Avatar
Member: 256342
Sonork: None
RIFF JTAG Manager 1.55
- Download update files speed is improved (Unlimited download speed)
- Removed PDF open buttons, instead embedded buttons with direct links to support site
The Following 10 Users Say Thank You to legija For This Useful Post:
Old 05-21-2016, 18:28   #88 (permalink)
legija's Avatar
Member: 256342
Sonork: None
JTAG Manager 1.60
- fixed bug related to some Server communication problems
- Transfer credits from account to account is simplified, no need to enter the destination Login name, the destination S/N is enough.
- link to RIFF Support forum is added on two dialog boxes (which are usually signal errors)
JTAG Manager 1.59
- changed the RIFFBOX pinout picture (added eMMC pinout interface on RJ-45)
- fixed bug in Package Editor: Flash Memory/Direct eMMC Flash actions, Automatic Parameters, building list of partitons for write via Plugins, was done with invalid lengths of paritions.
- [eMMC/SD Advanced]/[Select eMMC for Info & Read]: pictorgrams are added to the list of chips.
The pictogram is blue if info file is present, gray - if not present (the one displayed by the Show eMMC Testpoint button).
Firmware 1.39
- fixed JTAG bug with the ARM11 cores connection. Now is ok.
- fixed JTAG bug with the Cortex cores connection. Now is ok.
JTAG Manager 1.58
- added direct eMMC Access Interface on the RIFFBOX RJ-45 port (check pinout picture for CMD, CLK, DAT0, etc pins positions).
- added eMMC/SD Access page for Read/Write operations on eMMC/SD card via direct interface
- added eMMC/SD Advanced dialog which allows to perform advanced operations with eMMC/SD cards
(reading info, browsing through OCR, CID, CSD (and EXT_CSD for eMMC only) registers' fields, edit separate fields and writting back to card, reading/writting eMMC card's MCU's internal firmware, etc)
- added convenient information presentation for specific eMMC chips: pinouts for testpoints, manuals how to use testpoints to resurrect dead eMMC, etc). These INFO files (*.riffinfo) are stored in JTAG Manager's Documents folder and can be downloaded via generic <Check for Updates> operation.
- added eMMC Firmware Update option
- added eMMC Firmware Reading option (firmware is stored in *.riffemmcfw format)
For firmware read need to select chip from the list
- *.riffemmcfw eMMC firmware files are now used by RIFF for firmware updates (plain binary files are supported too)
- added elapsed time info for eMMC firmware update stages
- added eMMC Testpoint info displaying (info files must be downloaded from support and are located in the JTAG Manager's 'Documents' folder.
- added CMD42 Lock/Unlock functionality for eMMC. User can set/change/remove password to protect/unprotect (lock/unclock) the User Area Partition
- added the User Area Partition Forced Erase to erase Locked User Area Partition and to reset Device lock/unlock state and password (CMD42's consequences)
- added Samsung Factory Erase which erases and re-formats the Samsung eMMC chips.
- fixed bug displaying wrong SD card size for cards capacity less than 2GB
- few small improvements and bug fixes
Firmware 1.38
- added direct eMMC Access Interface functionality
- improved one thing in the emmc communication
- added the CMD42 Lock/Unlock/Pasword reset features
- added Forced erase of locked User Area Partition
- added Samsung eMMC Factory Format
- fixed bug for SD card support
- eMMC firmware update feature added
The Following 7 Users Say Thank You to legija For This Useful Post:
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.26590 seconds with 10 queries
