02-29-2012, 22:36 | #76 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 |
Please click “Check for Updates” button in order to download and apply new updates. |
The Following 5 Users Say Thank You to legija For This Useful Post: |
03-14-2012, 13:48 | #77 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Firmware 1.31 --------------------------- - APQ8060, MSM8260, MSM8660 (3rd generation Qualcomm chipsets) support is added. - fixed ARM7 bug: exit from debug state into THUMB mode was corrupted. - added after-halt "Emergency" script execution for ARM7 cores. JTAG Manager 1.41 --------------------------- - APQ8060, MSM8260, MSM8660 (3rd generation Qualcomm chipsets) support is added. - fixed SettingsCode bug which was spawned after we've transfered to 12-digit wide 64-bit hex numbers representation. |
The Following 6 Users Say Thank You to legija For This Useful Post: |
04-24-2012, 19:18 | #78 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | JTAG Manager 1.43 --------------------------- - added feature to use halt mode from a DLL rather than to use a default one. - added "DCC Loader USB Interface" feature. If selected resurrector (DCC Loader) supports USB communication (RIFF BOX DCCLoader USB Interface Port appears in windows devices list) then, after DCC Loader is started, the JTAG Manager will switch further communication with DCC Loader to the USB port thus data exchange speed will increase. Please note, to use this feature you need to attach USB cable from device to the PC USB port, and install drivers for "RIFF BOX DCCLoader USB Interface Port" on first use. DCC Loader USB Interface is not used during resurrection operations (Resurrection page, Resurrect button). |
The Following 4 Users Say Thank You to legija For This Useful Post: |
08-31-2012, 16:25 | #79 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 31.08.2012 : eMMC Partition Table FullFlash Image Files Processing Plugin (eMMCDiskPartitions.dll) v1.01 ------------------------------------- - Addded FLY partitions names to the list (based on Fly IQ285). |
10-18-2012, 14:03 | #80 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 18.10.2012 JTAG Manager 1.45 --------------------------- - ST-Ericsson NovaThor U8500 MCU support is added; - Updates List is now displayed in alphabetic order ("Check Updates" button on the "Box Service" page); - small cosmetic change to CTRL+F find form: CTRL+V/CTRL+X operations on ID search field starts search immediately; - added "Override Embedded Reset Strategy" feature: is usefull in rare cases when there are some problems with target coming out of reset, etc. The feature is accessible via "Advanced Settings" button on the "Box Service" page; - added "Apply NRST before connecting to target" (to setup click "Advanced Settings" button on the "Box Service" page); This feature is handy for development purposes especially when working with Qualcomm MCUs - after erroneous H/W config (most often is 0x45 error code) MSM locks down, to reconnect need to reset power. Enabling this feature simplifies this. Firmware 1.34 --------------------------- - ST-Ericsson NovaThor U8500 MCU support is added |
The Following 35 Users Say Thank You to legija For This Useful Post: |
11-16-2012, 17:40 | #81 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | JTAG Manager 1.46 --------------------------- - Added IDCODE analize and displaying known MCUs for that IDCODE. Click Analize JTAG Chain to see. - Added IDCODE API for DLLs; - Extended DCC Loaders Read/Write functionality to have separate buffers for read/write; |
The Following 9 Users Say Thank You to legija For This Useful Post: |
11-19-2012, 14:43 | #82 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | JTAG Manager 1.47 --------------------------- - Added new more APIs for Resurrector DLLs. These allow more flexible target initialization; - Added "PAUSE" feature which allows now JTAG Manager to work be "paused" on command from Remote Helper. Paused JTAG Manager frees RIFFBOX comport and becomes inaccessible until Remote Helper allows it to "unpause" Thus, Remote Helper may work without fear that user may meddle in process. |
11-28-2012, 19:16 | #83 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | JTAG Manager 1.48 --------------------------- - Added checking of plugin version before activation of it. - Nothing else is changed. New version of compiler used requires to update to 1.48 Please note, with older versions you will not be able to use plugins. Re-download all plugins again from support. |
The Following 8 Users Say Thank You to legija For This Useful Post: |
04-24-2013, 18:44 | #84 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 24.04.2013 RIFF JTAG - RIFF JTAG Manager v1.49, RIFF Box Firmware v1.35 released (Cortex-A15, Cortex-A5) Whats new: RIFF Box Firmware v1.35
The Following 132 Users Say Thank You to legija For This Useful Post: |
08-02-2013, 15:25 | #85 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | JTAG Manager 1.50 --------------------------- - Firmware update procedure is simplified now. To update box firmware user now has to click single button, no other actions are required!!! (in previous versions update firmware opration caused many questions from unexperienced users). - Update server moved to new host. Thus, Check Updates for Updates button will now work correctly. - Numlock key recognition is added so now additional keypad can be used to enter digits 0..9 into decimal fields (like address/length fields) |
The Following 33 Users Say Thank You to legija For This Useful Post: |
10-04-2013, 17:59 | #86 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | JTAG Manager 1.54 --------------------------- - password recovery is available during firmware update too. JTAG Manager 1.53 --------------------------- - added recovery password feature - some few irrelevant improvements JTAG Manager 1.52 --------------------------- - RIFFBOX Registration features enforced JTAG Manager 1.51 --------------------------- - added RIFFBOX Registration features - fixed few bugs related to Windows XP systems - fixed bug which caused sometimes to popup Firmware Update dialog while box firmware is already up to date. |
11-02-2013, 14:17 | #87 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | RIFF JTAG Manager 1.55 --------------------------- - Download update files speed is improved (Unlimited download speed) - Removed PDF open buttons, instead embedded buttons with direct links to support site |
The Following 10 Users Say Thank You to legija For This Useful Post: |
05-21-2016, 18:28 | #88 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | JTAG Manager 1.60 --------------------------- - fixed bug related to some Server communication problems - Transfer credits from account to account is simplified, no need to enter the destination Login name, the destination S/N is enough. - link to RIFF Support forum is added on two dialog boxes (which are usually signal errors) JTAG Manager 1.59 --------------------------- - changed the RIFFBOX pinout picture (added eMMC pinout interface on RJ-45) - fixed bug in Package Editor: Flash Memory/Direct eMMC Flash actions, Automatic Parameters, building list of partitons for write via Plugins, was done with invalid lengths of paritions. - [eMMC/SD Advanced]/[Select eMMC for Info & Read]: pictorgrams are added to the list of chips. The pictogram is blue if info file is present, gray - if not present (the one displayed by the Show eMMC Testpoint button). Firmware 1.39 --------------------------- - fixed JTAG bug with the ARM11 cores connection. Now is ok. - fixed JTAG bug with the Cortex cores connection. Now is ok. JTAG Manager 1.58 --------------------------- - added direct eMMC Access Interface on the RIFFBOX RJ-45 port (check pinout picture for CMD, CLK, DAT0, etc pins positions). - added eMMC/SD Access page for Read/Write operations on eMMC/SD card via direct interface - added eMMC/SD Advanced dialog which allows to perform advanced operations with eMMC/SD cards (reading info, browsing through OCR, CID, CSD (and EXT_CSD for eMMC only) registers' fields, edit separate fields and writting back to card, reading/writting eMMC card's MCU's internal firmware, etc) - added convenient information presentation for specific eMMC chips: pinouts for testpoints, manuals how to use testpoints to resurrect dead eMMC, etc). These INFO files (*.riffinfo) are stored in JTAG Manager's Documents folder and can be downloaded via generic <Check for Updates> operation. - added eMMC Firmware Update option - added eMMC Firmware Reading option (firmware is stored in *.riffemmcfw format) For firmware read need to select chip from the list - *.riffemmcfw eMMC firmware files are now used by RIFF for firmware updates (plain binary files are supported too) - added elapsed time info for eMMC firmware update stages - added eMMC Testpoint info displaying (info files must be downloaded from support and are located in the JTAG Manager's 'Documents' folder. - added CMD42 Lock/Unlock functionality for eMMC. User can set/change/remove password to protect/unprotect (lock/unclock) the User Area Partition - added the User Area Partition Forced Erase to erase Locked User Area Partition and to reset Device lock/unlock state and password (CMD42's consequences) - added Samsung Factory Erase which erases and re-formats the Samsung eMMC chips. - fixed bug displaying wrong SD card size for cards capacity less than 2GB - few small improvements and bug fixes Firmware 1.38 - added direct eMMC Access Interface functionality - improved one thing in the emmc communication - added the CMD42 Lock/Unlock/Pasword reset features - added Forced erase of locked User Area Partition - added Samsung eMMC Factory Format - fixed bug for SD card support - eMMC firmware update feature added |
The Following 7 Users Say Thank You to legija For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
