05-11-2020, 11:48 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: UK
Member: 196365 Status: Offline Thanks Meter: 35 | Huawei E5830 JTAG repair - successful Procedure: 1. connect, if no connection with board (I had no connection at all), go to: "Box Service" --> "Start Probing" and change in between options, new USB device will be found, and this is good indicator, now resurrection will connect and do the job. 2. Whatever I have done device was dead, or working just until I have switched off, or dead after ordinary software upgrade (file, which previously 100% was working fine) The magic answer: You need do dump from working device, and write it in "DCC Read/Write" as a full main (UNTICK: ECC module enabled) Then device will be working, will be accepting software upgrades, I have upgraded now with one of the files which previously in point two was damaging it again. Last edited by mahcin; 05-11-2020 at 11:56. |
The Following User Says Thank You to mahcin For This Useful Post: |
