Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Rocker Team products > RIFFBOX
Old 06-25-2012, 16:47   #1 (permalink)
Member: 1129443
jtag for samsung d710 - cant find dll
hi, i need do jtag for d710 and RIFF JTAG – Samsung SPH-D710 Galaxy S2 Epic Touch 4G (Samsung Within) Unbrick – dead boot repair supported « RIFF Box – JTAG Revolution
i cant find the dll anywhere i dont know what to do... plz help
Old 06-25-2012, 17:09   #2 (permalink)
Member: 1129443
the ressurector from this videos was writing from 0x000000000000 to 0x00005fffff and in the reset method use : preCFG0, nRST, Wait 0MS that i cant see on riff box firmware.. i need the .bin file and pinout file..
Old 06-25-2012, 20:50   #3 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Hi
Hi
Please goto "Box Services"...Press "Check for Update"....After few sec,You can see "Update Screen"...Then find "D710.dll in list...and double click..press "Download Selected"
Select "D710" in samsung list...Press"Resurrection Help" and read carefully
Also You Can Download From http://tracker.riffbox.org/details.php?id=49
RiffBox Setup 22.06.2012 v1
Old 10-17-2012, 00:58   #4 (permalink)
Member: 1826159
Hi there!,
I need support with the Riff Box for Samsung SPH-710 "Galaxy S II"
I want to "READ" Download the internal memory of the phone but it keeps Beeping 5 times after it gets to an address.. I keep trying to continue where it left off but is seems to be stuck at an address.
How do I know if the phone is On and communicating?
I wonder if the phone is shutting off...
Can and should I use the 4.2V out to provide (virtual battery) power?
What I do now is plug the PHONE USB cord to the computer, then insert the Battery to turn it on.
I also tried turning it on with or without the battery by providing power VIA USB only (powered by the computer).
FYI: the USB port on the RIFF box doesn't seem to work well (yes, I did enable it in the advanced settings) ...
I get a better response from the phone when it is powered direct from the PC..
Should I use a power adapter instead?
History:
The phone failed after being wet by rain...
I took it apart cleaned it and dried it thoroughly...
It responds well but the screen no longer works...
So I try to power it up with or without the screen connected...
It works better I think with the screen disconnected.. Is this the right way?
I want to recover the memory inside before doing anything to it that will erase the data... Should I try "Resurrecting"?
What does it mean when the JTAG Manager beeps 5 times, when trying to read?
If the Green Data light doesn't flash anymore does that mean that the phone shut off?
I wish the box/software were more informative so that I know what to check or what is the cause...
Should I use "JTAG READ/WRITE" or "DCC READ/WRITE"
Are there any specific instructions on how to (READ) Backup the data through JTAG?
Please let me know
Thanks
-J
Below some of the Screen Messages:
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.33, JTAG Manager Version: 1.44
Selected Resurrector: [Samsung SPH-D710 V1.0.4514.6533]
Connecting to the dead body...OK
Detected dead body ID: 0x4BA00477 - CORRECT!
Set I/O Voltage reads as 2.80V, TCK Frequency is 8 MHz
Settings Code: 0x23010B00000000000000000080000000
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (MAG4FA, 0x0003AB400000 Bytes = 14.68 GB)
Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (MAG4FA, 0x000000080000 Bytes = 0.50 MB)
Looking for the RIFF BOX DCCLoader USB Interface Port...FAILED
The DCCLoader USB Interface is not found. Communication continues over the DCC Interface
WARNING: Resuming interrupted read from 0x000002D60000, yet to read - 0x00007D2A0000...
Reading FLASH1 address space from 0x000002D60000 to 0x00007FFFFFFF
Failed to receive answer to READ command.
Settings Code: 0x22020B00000000000000000040000000
WARNING: Resuming interrupted read from 0x000000000000, yet to read - 0x000400000000...
Reading FLASH2 address space from 0x000000000000 to 0x0003FFFFFFFF
Old 10-17-2012, 12:12   #5 (permalink)
legija's Avatar
Member: 256342
Sonork: 100.45940
RIFF JTAG Box FAQ - Failed to receive answer to READ command..
RIFF JTAG Box FAQ - JTAG Manager - DCC Read/Write TAB
The Following User Says Thank You to legija For This Useful Post:
Old 03-15-2013, 13:04   #6 (permalink)
Member: 1696107
Sonork: 100.1627795
please hel me legija for this problem
Firmware Version: 1.34, JTAG Manager Version: 1.48
Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz
Uploading resurrector data into memory...FAILED
ERROR: RAM memory selftest failed.
please explain me to fix this trouble....
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
Operator-Logo for 5110 MiMiR the WiseMan Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 06-25-1999 15:50
Page generated in 1.30810 seconds with 11 queries
