04-24-2012, 19:59 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | @ Legija and team : Wildfire S touch screen unstable problem... Wish to ask you about this strange problem maybe you met it and know the source pls.I am meeting an ever increasing amount of units of this model with this same problem after changing its digitizer. The unlock ring at first wont move at first touch and then after some 10-20 seconds works (but quite in an awkward way). This repeats itself whenever the phone is locked. Otherwise the phone works normally. Tried various types of brands, even original digitizers with the same effect. Could this be some internal value such as the proximity sensor pls? I cannot understand what is going on. Am hoping that there is something i can use with RIFFbox to help me solve this problem. Thanks for any feedback and advice |
04-24-2012, 20:06 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | MISC_MFG partition contains board revision info, from where software reads what drivers to load upon startup. Since You need solution after changing original digitizer, i have no freaking idea what to write there. |
04-24-2012, 21:38 | #4 (permalink) |
Freak Poster Join Date: Aug 2010
Member: 1379587 Status: Offline Sonork: 100.1619552 Thanks Meter: 29 | Easy to fix this issue use goldcard made from x*c clip insert it follow the procedure from x*c clip, click volume down for diag before you do this make sure the wildfire s is flat down on a surface and then it will start calibrating the digitizer and its done :d |
The Following 3 Users Say Thank You to Unlock_Master For This Useful Post: |
05-22-2012, 12:36 | #6 (permalink) |
Insane Poster Join Date: May 2002 Location: Spain Age: 43
Member: 11980 Status: Offline Thanks Meter: 0 | this solution is not working. tested. touch panel will work but not the right side and also the home, back, etc... buttons. Now looking for solution. note: there are 2 types of touch panels for wildfire S. maybe this is the problem. look this: http://forum.gsmhosting.com/vbb/atta...7&d=1329344473 Last edited by Shulo; 05-22-2012 at 12:43. |
05-22-2012, 13:08 | #7 (permalink) | |
Member: 11980 Status: Offline Thanks Meter: 0 | Quote:
i have here 2 wildfire S one is working with touch panel and the other isnīt working with same touch panel. can i read MISC_MFG partition with RIFF box? thanks. | |
05-22-2012, 14:04 | #8 (permalink) | |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Quote:
You can use "Qualcomm fullflash image processing tool" from Useful plugins TAB. | |
The Following User Says Thank You to legija For This Useful Post: |
05-22-2012, 18:04 | #10 (permalink) |
Member: 11980 Status: Offline Thanks Meter: 0 | bad news... i flashed the nonworking phone with this (full spare+data) and still not working, so i think this is not the solution... :-( attached here also the nonworking MISC_MFG files |
05-22-2012, 20:13 | #11 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | You flashed just empty files lol Once you "get partitions from device", You actually need to READ given partition, not just save empty created placeholders. So, procedure should be like this: 1. Connect working phone, click "Get partition from device" 2. Select MISC_MFG partition, and click "Read partition" 3. Connect dead and click "Flash partition" Of course, both phones must have 2kb page size. |
