06-19-2013, 10:08 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Kazakhstan
Member: 19032 Status: Offline Thanks Meter: 158 | LG F160S QHSUSB_DLOAD mode I tried repair boot with RIFF, but not success: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [LG F160S V1.0.4695.3279] Connecting to the dead body...OK Detected dead body ID: 0x406B50E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...ERROR ERROR: No response from the RIFF Box. What may be? |
06-19-2013, 10:48 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | RIFF JTAG Box FAQ - ERROR: No response from the RIFF Box. This can be HW problem with device, but in most cases it's caused by bad connection. |
06-22-2013, 11:15 | #3 (permalink) |
Member: 19032 Status: Offline Thanks Meter: 158 | In my case repair boot, only when i check RTCK Frequency is 1 MHz Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [LG F160S V1.0.4695.3279] Connecting to the dead body...OK Detected dead body ID: 0x406B50E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0011/0x0000 (016G8B, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0011/0x0000 (016G8B, 0x000000200000 Bytes = 2.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14,68GB Flashing the dead body...OK Resurrection complete! |
