03-25-2015, 11:28 | #1 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2249953 Status: Offline Sonork: 100.1614969 Thanks Meter: 9 | Lg lu6200 error cant repair boot plz help Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [LG LU6200 V1.0.5025.52349] Connecting to the dead body...OK Detected dead body ID: 0x105310E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0090/0x014A (HYNIX, 0x0000D7800000 Bytes = 3.37 GB) Detected an Initialized FLASH2 Chip, ID: 0x0090/0x014A (HYNIX, 0x000000200000 Bytes = 2.00 MB) Flashing the dead body... WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. ERROR: DCC Loader has reported Error Code = 0x3E (0x007FFF <> 0x020000) |
05-10-2016, 02:24 | #3 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Deira, Dubai
Member: 2062071 Status: Offline Sonork: 100.1663486 Thanks Meter: 60 | Lg lu6200 error cant repair boot plz help Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [LG LU6200 V1.0.5025.52349] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x105310E1 - IGNORED! WARNING: Embedded I/O Voltage is overriden to 3.30V Set I/O Voltage reads as 3.32V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: No response from the RIFF Box. |
05-10-2016, 03:31 | #4 (permalink) |
Member: 2062071 Status: Offline Sonork: 100.1663486 Thanks Meter: 60 | Lg lu6200 error cant repair boot plz help Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [LG P930 V1.0.4801.52435] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x105310E1 - IGNORED! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
05-10-2016, 03:32 | #5 (permalink) |
Member: 2062071 Status: Offline Sonork: 100.1663486 Thanks Meter: 60 | Lg lu6200 error cant repair boot plz help Lg lu6200 error cant repair boot plz help Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [LG P930 V1.0.4801.52435] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x105310E1 - IGNORED! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
