04-01-2015, 10:30 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | lt30p read boot ?? Set I/O Voltage reads as 1.81V, TCK Frequency is 1 MHz Settings Code: 0x02000600000000000000000080000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0100 (SEM16G, 0x0003B5400000 Bytes = 14.83 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0100 (SEM16G, 0x000000200000 Bytes = 2.00 MB) Reading MCU address space from 0x000000000000 to 0x00007FFFFFFF Failed to receive answer to READ command. |
04-01-2015, 12:28 | #2 (permalink) |
Member: 718470 Status: Offline Thanks Meter: 79 | i read with jtag from a working phone lt30p (i chosed custom size 512mb) and i tried to write the file i read to the dead phone and i get the following errors : Connecting to the dead body...OK Detected dead body ID: 0x407910E1 Set I/O Voltage reads as 1.81V, TCK Frequency is 1 MHz Settings Code: 0x2801060000000000000000001FFFFFFF Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000036 ERROR: Main data file size is less than requested to flash to main. pls tell if i did something wrong or what to do next. cand i succesfully copy the boot from the working phone ? br, gsmiulian |
