03-25-2014, 18:38 | #1 (permalink) |
No Life Poster Join Date: Nov 2003
Member: 44904 Status: Offline Thanks Meter: 45 | Lumia 520 error Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Nokia Lumia 520 V1.0.5149.18900] Connecting to the dead body...OK Detected dead body ID: 0x207D00E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 2 MHz] Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x42): Communication is not established. Terminating. conected batery and usb |
03-25-2014, 18:39 | #2 (permalink) |
Member: 44904 Status: Offline Thanks Meter: 45 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Nokia Lumia 520 V1.0.5149.18900] Connecting to the dead body...OK Detected dead body ID: 0x207D00E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x42): Communication is not established. Terminating. |
02-05-2015, 16:06 | #6 (permalink) |
Major Poster Join Date: Jun 2004 Location: andalas Age: 45
Member: 68676 Status: Offline Thanks Meter: 8 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Nokia Lumia 520 V1.0.5149.18900] Connecting to the dead body...OK Detected dead body ID: 0x207D00E1 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x44): Communication is not established. Terminating. |
02-06-2015, 05:45 | #7 (permalink) | |
Product Supporter Join Date: May 2004 Location: INDIA Age: 55
Member: 65063 Status: Offline Thanks Meter: 2,419 | Quote:
Check wire length, must be shortest Check supply , better use usb with power supply on battery points Use power button while halting br, | |
