07-19-2013, 11:21 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: City of Temples
Member: 729381 Status: Offline Thanks Meter: 248 | M110s baseband i need to repair baseband and imei for this set what is the correct address and length for writing efs file for samsung M110s? I got this error while using settings for i9000 from here http://forum.gsmhosting.com/vbb/f634...i-2-a-1661209/ I selected efs in spare,write successfully but killed it, then revived after resurrection,and still baseband unknown |
07-19-2013, 23:54 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi You need reflash phone with full firmware on odin correct full rom is 600-700 mb..... update fw rom is 300-400mb -- So,You need full firmware... ---------------- if still you have problem after flash full fw ,Follow this Open i9000 Plugin load dump file and make partition from file select efs partition and press "Write" |
The Following 2 Users Say Thank You to BABAK NURI For This Useful Post: |
07-21-2013, 10:37 | #5 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 694525 Status: Offline Thanks Meter: 31 | try this metod, i have done 3 times with this http://forum.gsmhosting.com/vbb/f777...-here-1515778/ |
07-22-2013, 09:54 | #10 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi This is unstable Power or Bad soldering Just double check jtag wires,then connect usb cable and power supply Speed at 8 or max on TCK And Try again for writing dump file |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
