08-23-2017, 14:41 | #1 (permalink) |
Freak Poster Join Date: May 2013
Member: 1939490 Status: Offline Sonork: 100.1638723 Thanks Meter: 22 | moto g4 plus frp by riff ? Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.46 (RIFFBOX1), JTAG Manager Version: 1.71 Connecting to the SD/eMMC Card...OK Set I/O Voltage reads as 2.81V, SD_CLK Frequency is 2.50 MHz Detected eMMC Chip, ID: 0x15/0x00 (RX1BMB), User Area Partition = 0x000747C00000 Bytes (29.12 GB) Invalid length. It should not be zero. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.46 (RIFFBOX1), JTAG Manager Version: 1.71 Connecting to the SD/eMMC Card...OK Set I/O Voltage reads as 2.81V, SD_CLK Frequency is 2.50 MHz Memory Type .......................... eMMC Manufacturer ID ...................... 0x15 OEM/Application ID ................... 0x00 Product Name ......................... "RX1BMB" Package .............................. BGA User Area Partition Size ............. 0x000747C00000 Bytes (29.12 GB) Boot Partition Size .................. 0x000000400000 Bytes (4.00 MB) RPMB Partition Size .................. 0x000000400000 Bytes (4.00 MB) OCR Register ......................... 0xC0FF8080 (Dual Voltage, High Capacity) Write Protection Bits ................ NONE Boot Configuration ................... Boot from User Area (Bus Width = 1Bit) Chip Revision ........................ 0.7 Multimedia Card Revision ............. 1.8 (UNKNOWN) Serial Number ........................ 0x93E7D00D Memory Manufacturing Date ............ May, 2016 |
The Following User Says Thank You to ahsan.mt For This Useful Post: |
10-06-2017, 21:43 | #4 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, Please create ticket in "New models support request". We can't handle such tickets here. https://goo.gl/ntJZAS Thanks. |
