04-04-2011, 08:57 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Rajasthan Age: 41
Member: 227647 Status: Offline Sonork: 100.1603662 Thanks Meter: 311 | Mr. legija (do only copy paste) The One & ony reason is "Mr.legija know only how to copy solution" we all knows that riff is doing only copy for trace32 & still trace32 is not supporting qsc1100 so it is not possiable for riff to support qsc1100 & still riff is not supporting any model which is not supported by trace32. therefore i know that Mr. legija only doing copy paste so this is waste for asking for new models which is not supported in trace32. |
04-04-2011, 09:37 | #3 (permalink) | |
No Life Poster Join Date: Mar 2002 Location: gsmcity Age: 45
Member: 10505 Status: Offline Sonork: 100.40828 Thanks Meter: 364 | Quote:
Don't say things which you don't know exactly. RIFF deam don't have trace32 and no need it to add new solutions. So, colmdown and continue use your lovely trace32. BR levsha | |
04-04-2011, 09:55 | #4 (permalink) |
Member: 227647 Status: Offline Sonork: 100.1603662 Thanks Meter: 311 | Prove urs ability here is the list of Processors supported by trace32 add just a single model which is not in this list & i will keep my ***** shut. |
04-04-2011, 10:00 | #5 (permalink) | |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Quote:
You already posted screenshots where You managed to halt this cpu. http://forum.gsmhosting.com/vbb/7144981-post15.html So clearly CPU it self is of course supported. It is another thing to get working DCC loader with different types of memory. As i can see from those screens, You tried to read RAM and it was working. Have You tried to read flash memory using DCC Read/Write TAB ? | |
The Following User Says Thank You to legija For This Useful Post: |
04-04-2011, 10:03 | #6 (permalink) | |
Member: 227647 Status: Offline Sonork: 100.1603662 Thanks Meter: 311 | Quote:
sir thanks for reply. as per screenshot u can see the cpu is connect & helt ok but i have not tried to read full flash using dcc read/ write tab. for pinout just go here (allready posted by me in this great forum) http://forum.gsmhosting.com/vbb/7151434-post21.html Last edited by Winner58; 04-04-2011 at 15:29. Reason: email removed | |
04-04-2011, 10:31 | #7 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: GSM WORLD
Member: 898387 Status: Offline Sonork: 1000.2 Thanks Meter: 103 | Quote:
04-04-2011, 11:20 | #8 (permalink) | |
Try using DCC feature of QSC6xxx DLL and report. And DO NOT insult members here. | |
04-04-2011, 11:31 | #9 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | Quote:
You made a simple question with roudly language. thats the wrong way. sorry i dont like it. There are a lot of diffrence between blaiming and asking bro. hope you can better understand. | |
04-04-2011, 11:33 | #10 (permalink) | |
best wishes for you friend you have a lot of self control. | |
04-04-2011, 12:11 | #11 (permalink) | |
& now i tried with dcc read write its not working so please add this while using DCC feature of QSC6xxx DLL log is : Connecting to the RIFF Box...OK Firmware Version: 1.21, JTAG Manager Version: 1.29 Selected Resurrector: [QSC6XXX L36 D08] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - IGNORED! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. & without bypass of id : Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.21, JTAG Manager Version: 1.29 Selected Resurrector: [QSC6XXX L36 D08] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. | |
04-04-2011, 13:37 | #12 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Ok, this is better. Why You used QSC6xxx designed for NAND memory chips? So far all CDMA devices were with NOR chips, hence You need to use QUALCOMM NOR DLL-s. Since there is two QSX6xxx NOR DLL-s, with different dividers, first start with "QSC6xxx L20_D08". Please DO NOT use maximum RTCK sampling with QSC cpu-s. It wont work. Try different RTCK sampling rates, 1MHz, 2, etc. |
04-04-2011, 22:46 | #14 (permalink) | |
Freak Poster Join Date: Jun 2010
Member: 1331936 Status: Offline Thanks Meter: 12 | Quote:
i think it is smart to do copy paste in programming skills can u do you ???? stop your BLA BLA and respect people that do something real than talking Bul l S Hi TS no regards | |
04-05-2011, 15:38 | #15 (permalink) |
Freak Poster Join Date: Aug 2006 Location: R A J A S T H A N
Member: 333796 Status: Offline Sonork: 100.1587155 Thanks Meter: 83 | stop banning .. worn frist then will banne Its not a support ... Its show only "YOU" have power of banne. Respect Costemer thay is *** . Last edited by rekha1255; 04-05-2011 at 15:44. |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
