06-05-2018, 05:28 | #4 (permalink) |
Product Supporter Join Date: May 2004 Location: INDIA Age: 55
Member: 65063 Status: Offline Thanks Meter: 2,419 | |
06-05-2018, 06:35 | #6 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,419 | Windows encountered a problem installing the driver software for your device. Windows found driver software for your device but encoutered an error while attempting to install it. The hash for the file is not present in the specified catalog file. The file is likely corrupt or the victim of tampering. To solve this problem, You have to disable Device Driver Signing. Here’s how it’s done in Windows 10. Option 1 – Command to Enable or Disable Click the “Start” button. Type “command“. Right-click on “Command Prompt” and select “Run As Administrator“. Do one of the following: To disable device driver signing, type “BCDEDIT /set nointegritychecks ON” then press “Enter“ To enable device driver signing, type “BCDEDIT /set nointegritychecks OFF” then press “Enter“ You’re done! The Device Driver setting is now modified. Option 2 – Disable From Menus Security that was built into Windows to prevent you from installing unsigned or foreign drivers. This is a feature called Device Driver Signing. After going through the steps to disable driver signing in Windows 8, you il be able to get your desired drivers installed. Select the “Start” button. Type “startup”. Select “Change advanced startup settings“. Select “Restart now” under the “Advanced startup” area. Select “Troubleshoot“. Select “Advanced Options“. Select “Startup Options“. Select “Restart“. A menu will appear where you can press “7” on your keyboard to choose “Disable driver signing enforcement“. Now Device Driver Signing should be disabled, allowing you to install any driver you like in Windows 10 until you reboot. br, |
06-10-2018, 07:03 | #8 (permalink) |
Crazy Poster Join Date: Jun 2014
Member: 2203177 Status: Offline Thanks Meter: 9 | Please help my riff with no firmware I tried installing and updating my riff Everything seems good but I still get this I am using windows 32bit operating system hope everyone helps |
06-10-2018, 10:40 | #9 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, Download this archive and extract it: https://drive.google.com/open?id=1sy...iv-XkEO8_JGF_A 1. Disable driver signature enforcement ( https://www.youtube.com/watch?v=ccEI29E9qlE ) 2. Open 32bit dir and run "Clean.bat" 3. Restart Windows 4. Run "Install.bat" (confirm installation of unsigned drivers each time) 5. Restart Windows again 6. Connect RIFF Box, start device manager -> ports -> set RIFF controll port comport number to less than 10 (e.g. 3 or 4) 7. Reconnect RIFF box and click "Firmware Update" 8. After You see "Setting Update Mode... . . ." Reconnect box on USB cable and Windows should install Update port driver automatically. If not, You need to do it manually. In case if it fails first time, just repeat step 7. |
The Following 2 Users Say Thank You to legija For This Useful Post: |
06-11-2018, 11:32 | #12 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | I dont think so. Most probably You didn't understood my instructions. Please contact me via QQ (or any other supporter) so firmware update can be done via remote desktop. |
06-12-2018, 02:13 | #13 (permalink) |
Freak Poster Join Date: Oct 2013 Location: italy
Member: 2048673 Status: Offline Thanks Meter: 62 | Firmware update problem Open serial port...OK Connecting to the RIFF Box...OK Getting RIFF Box Info...OK RIFF Box Bootcore Version: 1.01 (RIFFBOX1) Connecting to the Updates Server...OK Downloading new Firmware from Server...OK Setting Update Mode...OK Updating Box's Firmware...OK Restarting box, please wait...OK Firmware Update Completed OK Current Firmware Version: RECOVERY (RIFFBOX1) Open serial port...OK Connecting to the RIFF Box...ERROR ERROR: At least 1.50 Box's Firmware Version is required. Current version is RECOVERY. Please update BOX Firmware. Last edited by legija; 06-12-2018 at 07:51. |
06-12-2018, 02:46 | #14 (permalink) |
Member: 2048673 Status: Offline Thanks Meter: 62 | Getting RIFF Box Info...OK RIFF Box S/N: RIFF Box Firmware Ver Open serial port...OK Connecting to the RIFF Box...OK Getting RIFF Box Info...OK RIFF Box Bootcore Version: 1.01 (RIFFBOX1) Connecting to the Updates Server...OK Downloading new Firmware from Server...OK Setting Update Mode...OK Updating Box's Firmware...OK Restarting box, please wait...OK Firmware Update Completed OK Current Firmware Version: RECOVERY (RIFFBOX1) Open serial port...OK Connecting to the RIFF Box...ERROR ERROR: At least 1.50 Box's Firmware Version is required. Current version is RECOVERY. Please update BOX Firmware. |
06-12-2018, 12:28 | #15 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Baia Mare Age: 44
Member: 158975 Status: Offline Thanks Meter: 17 | manager 1.79, fw 1.50 ...now recovery Open serial port...OK Connecting to the RIFF Box...OK Getting RIFF Box Info...OK RIFF Box Bootcore Version: 1.01 (RIFFBOX1) Connecting to the Updates Server...OK Downloading new Firmware from Server...OK Setting Update Mode...OK Updating Box's Firmware...OK Restarting box, please wait...OK Firmware Update Completed OK Current Firmware Version: RECOVERY (RIFFBOX1) at 3% stop, error response from box, try again 2 times but show this after tks |
