04-17-2013, 14:27 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Gujrat (India) Age: 38
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | N7000 boot repair error how to repair this? ----------------------------------------------- Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung N7000 V1.0.4715.8614] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. -------------------------------------------- Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung N7000 V1.0.4715.8614] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x0000003A No Resurrection Data is available for the eMMC Chip with Capacity = 0B WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14.68GB ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
04-17-2013, 15:04 | #2 (permalink) | |
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | Quote:
Finally got the problem emmc ic was cracked Need to Replace it.... | |
05-06-2013, 20:55 | #3 (permalink) |
Insane Poster Join Date: May 2008 Location: INDIA
Member: 771053 Status: Offline Thanks Meter: 5 | Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung N7000 V1.0.4860.58267] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x03010043 No Resurrection Data is available for the eMMC Chip with Capacity = 0B WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14.68GB ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
05-06-2013, 21:32 | #4 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
if you have any problem,Please Open New Topic....Don't Update Old Topic... Anyway,You need Replace eMMC Please Read:RIFF JTAG Box FAQ - WARNING: DCC Loader was unable to initialize FLASH1 chip. | |
11-28-2013, 14:15 | #5 (permalink) |
Insane Poster Join Date: Jan 2013 Location: malaysia Age: 41
Member: 1862581 Status: Offline Sonork: 100.1658771 offline Thanks Meter: 13 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung N7000 V1.0.4860.58267] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000048 No Resurrection Data is available for the eMMC Chip with Capacity = 0B WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14,68GB ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
