09-19-2013, 13:49 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | n7000 dead-resurrection error posted-help Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000048 No Resurrection Data is available for the eMMC Chip with Capacity = 0B WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14.68GB ERROR: Selected FLASH Chip was not initialized by the DCC Loader. why above error? is it hardware? |
09-19-2013, 15:13 | #2 (permalink) |
Member: 946381 Status: Offline Thanks Meter: 150 | the same problem in below link http://forum.gsmhosting.com/vbb/f634...-help-1711427/ and answer as """""this is emmc brick you should to change emmc""""""" supporters is it right answer? |
