12-10-2012, 06:52 | #1 (permalink) |
Freak Poster Join Date: Mar 2011 Location: in BIGSERVER
Member: 1542932 Status: Offline Sonork: 100.1621006 Thanks Meter: 53 | n7000 hard bricked, please help Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung N7000 V1.0.4715.8614] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x0000003A No Resurrection Data is available for the eMMC Chip with Capacity = 0B WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14.68GB ERROR: Selected FLASH Chip was not initialized by the DCC Loader. loking like emmc chip is damage, can we use any mmc as emmc? to run phone ok. please provide solution. thanks |
12-10-2012, 08:03 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Yes,This is clear case of damaged eMMC -- No,You Can't use any eMMC....You can use only from Exynos4210 or Omap4430-4460 |
