Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 09-08-2013, 11:49   #1 (permalink)
rajesh_ch's Avatar
Member: 618404
Thanks Meter: 311
n7000 resurettion failed pls help
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.37, JTAG Manager Version: 1.51
Selected Resurrector: [Samsung N7000 V1.0.4860.58267]
Connecting to the dead body...OK
Detected dead body ID: 0x4BA00477 - CORRECT!
Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x03010043
No Resurrection Data is available for the eMMC Chip with Capacity = 0B
WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14.68GB
ERROR: Selected FLASH Chip was not initialized by the DCC Loader.
Old 09-08-2013, 20:32   #2 (permalink)
ALI MAJIDINIA's Avatar
Member: 1933631
Sonork: 100.1618169
Thanks Meter: 52
hi
plz use search tab
this is emmc brick
you should to change emmc
br
majidinia
Old 09-11-2013, 18:11   #3 (permalink)
Member: 685
Thanks Meter: 23
check u301.had one today,was water damaged,symptoms were the same,no emmc detected
Page generated in 0.17541 seconds with 8 queries
