12-31-2012, 05:35 | #1 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: Hanoi, Vietnam
Member: 1012390 Status: Offline Thanks Meter: 95 | Need full dump for One S Ville (S4), please I have a dead HTC One S, resurrect successfull by riff but phone not boot. The first, i only repair hboot (SPL version), CID, imei successfull but phone not get bootloader, always black screen. But i plugin cable with PC, phone boot in to a stuck mode, always there but it still black screen. Try with command "adb devices" and the windows return the id of devices in recovery Then go on with "adb reboot-bootloader", it reboot to fastboot but phone still black screen. I attemped to flash RUU but always failed, with these steps "adb reboot-bootloader" "fastboot oem rebootRUU" "fastboot flash zip rom.zip" with rom.zip is stock extract from Ville RUU sending zip..... but then failed, sorry i forget to write it down. Second time, resurrect with all option (Recovery Zones, WLAN partition, HTC Partition) Now phone lost stuck in recovery mode, can connect via adb But it still boot, and PC detect Android phone, but still black screen The lcd screen OK because when customer send it to me, it can show htc logo but cannot get hboot. How can i solve this problem? Pls help with you kind! Thank so much! Quote:
12-31-2012, 05:39 | #2 (permalink) |
Member: 1012390 Status: Offline Thanks Meter: 95 | Srr, miss letter Second time, resurrect with all option (Recovery Zones, WLAN partition, HTC Partition) Now phone lost stuck in recovery mode, can not connect via adb But it still boot, and PC detect Android phone, but still black screen |
12-31-2012, 21:53 | #3 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi I did explain in sonork... But Try This: 1-Resurrect again with all option.. 2-assemble phone 3-hold vol down and press power 4-after 4sec..release both key 5-press again power on key...1 sec 6-connect USB cable 7-open cmd and run..."fastboot getvar all" Then run latest RUU and Try For reflash ----- Post result plz |
01-07-2013, 20:43 | #4 (permalink) |
Member: 1012390 Status: Offline Thanks Meter: 95 | Hi Mr Babak, I tried with all the steps same that you guide but everything no more clearer I just get a HTC One S T-Mobile dead boot and RIFF repair successfull and keep it alive back. I just full erase then repair with full options, it can show htc screen then turn off when i enter bootloader, but not enter boot |
01-09-2013, 20:44 | #5 (permalink) |
Member: 1012390 Status: Offline Thanks Meter: 95 | Hi, Finally i can enter bootloader. After many time tried to enter bootloader and i can get it. The phone now alive. Confirm Riff working good with HTC Ville, Ville (T-Mobile) and also Ville C (One S S3) Thank Riff Team! |
01-11-2013, 04:17 | #8 (permalink) | |
Member: 1012390 Status: Offline Thanks Meter: 95 | Quote:
I solder wires and resurrect bricked phone as normally. I get the one as the same with you, customer S-CID it then flash another hboot to upgrade to JB and phone stuck at QHSUSB_DLOAD. Only one time to resurrect phone and it OK but with one S4 Europe, it so hard to enter bootloader | |
The Following User Says Thank You to Hoayeu105 For This Useful Post: |
01-11-2013, 16:52 | #9 (permalink) | |
Junior Member Join Date: Jan 2013
Member: 1866541 Status: Offline Thanks Meter: 0 | Quote:
01-12-2013, 04:17 | #11 (permalink) |
Member: 1012390 Status: Offline Thanks Meter: 95 | I posted all about it at here: HTC Ville (One S S4) T-Mobile repair boot OK - CLB H In 2nd post, the picture is S4 Europe |
01-12-2013, 04:27 | #12 (permalink) | |
Member: 1012390 Status: Offline Thanks Meter: 95 | Hi, i just check again by the firmware i flashed for it and glad to report to you that T-Mobile is modelid: PJ4011000 Quote:
01-12-2013, 17:25 | #13 (permalink) | |
Ah good good. so all I have to do is. thou i borrowed riff box from my friend and was all set to to start but at last moment I panicked I went to my friends place for help but unfortunately he had to go so now my phone is at professional repair shop. so I am glad T-mobile one s can be repaired. So all you have to do is 1) open phone 2) solder jtag connections 3) open riff manager 4) select HTC one S (PJ40100) 5) select resurrect 6) assemble phone back 7) flash stock rom from HBOOT is this correct. or do you have select any options for T-Mobile One S | |
01-12-2013, 18:42 | #14 (permalink) | |
01-13-2013, 00:31 | #15 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Guys,Please Note, if You Have Any Other Variant Like,T.Mobile or AT@T or Bell....if You Select WWE DLL For Repair Phone,Your Phone Convert To WWE Version,So...You Need Reflash Phone With WWE RUU After Flashing Done,Some Case Work Properly Also Some Case Not Work Properly..For Ex: Network/BT/Wifi Problem or Signal or Proximity Sensor... |
