10-02-2012, 09:57 | #1 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 198016 Status: Offline Sonork: 100.1602918 Thanks Meter: 408 | need help i9100 dead Detected dead body ID: 0xFFFFFFF0 - WRONG!!! ERROR: Current ID does not belong to the Samsung i9100 family. |
10-03-2012, 00:17 | #5 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi It's means you have a "G" Version... So,Please Check PCB --- if you have a I9100G.You Can Repair Via Omap-Flasher if you have a I9100...You Need Check Connection |
01-06-2013, 17:52 | #6 (permalink) |
Junior Member Join Date: Feb 2004 Age: 58
Member: 52625 Status: Offline Thanks Meter: 0 | I have the same problem , I'm sure the phone is i9100 ,the connection is correct (the same pinout of riff ) but: Connecting to the dead body...OK Detected dead body ID: 0xFFFFFFF0 - WRONG!!! ERROR: Current ID does not belong to the Samsung i9100 family. Any solution or procedure? thanks |
01-08-2013, 00:20 | #11 (permalink) |
Member: 52625 Status: Offline Thanks Meter: 0 | "" Quote: Originally Posted by fregna View Post view my capture you have different target id in logs, so probably you have mistake somewhere "" many times I've read and I always get different the problem is that we never learn exactly s2 id, I get many 0xffffff ... |
04-20-2013, 11:10 | #12 (permalink) |
Freak Poster Join Date: Jun 2011 Location: manila/makati city/philippines
Member: 1598381 Status: Offline Sonork: 1595992 Thanks Meter: 20 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung i9100 V1.0.4582.4854] Connecting to the dead body...OK Detected dead body ID: 0x00FFFFFF - WRONG!!! ERROR: Current ID does not belong to the Samsung i9100 family. update this thread!!!!!!!!!!!!!!!!!!!!!!!!!! |
09-04-2014, 06:04 | #14 (permalink) | |
Insane Poster Join Date: May 2014 Location: BANGLADESH
Member: 2192293 Status: Offline Sonork: 100.1682767 Thanks Meter: 60 | Quote:
It's mostly GND connection problem and other connection deeply solder the your PCB........100% solved your problem......i have done it now...... | |
