01-09-2013, 14:30 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | need help regarding this htc wildfire error.. hare is its resurrection log ... i have make the connection two times but same error..ribbon is good and connection are also good .. i have also check this page for this error RIFF JTAG Box FAQ - powered by phpMyFAQ 2.7.5 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC Wildfire V1.00] Connecting to the dead body...OK Detected dead body ID: 0xC01B30E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x55BC (512MB) Selected Resurrection Data for the NAND Chip with Page size = 2KB Flashing the dead body... ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000000000000 this is read dump log its also give error... Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x55BC (512MB) Looking for the RIFF BOX DCCLoader USB Interface Port...FAILED The DCCLoader USB Interface is not found. Communication continues over the DCC Interface Reading FLASH1 address space from 0x000000000000 to 0x00001FFFFFFF Failed to receive answer to READ command. Last edited by digitized; 01-09-2013 at 14:36. |
