01-30-2013, 06:35 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Age: 28
Member: 745672 Status: Offline Thanks Meter: 555 | Need Help Samsung S8530 Cant Enter Boot Mode after Resurrtion my phone total dead,, what wrong ?? plz Team Help me Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung S8500 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 4 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Flashing the dead body...OK Resurrection complete! |
01-30-2013, 06:59 | #5 (permalink) |
No Life Poster Join Date: Feb 2008 Location: +919304287474 Age: 41
Member: 714710 Status: Offline Sonork: offline Thanks Meter: 1,017 | Flash Mode: Hold Volumn - And Camera Key. Press Power On Key Enter Download Mode ----------------------------------------------------------------------------- |
01-30-2013, 07:02 | #6 (permalink) |
No Life Poster Join Date: May 2010 Location: Punjab Age: 36
Member: 1298426 Status: Offline Sonork: 100.1603765 Thanks Meter: 266 | here is the full Procedure bro may it helps u RIFF JTAG – Samsung WAVE S8500 Unbrick/Repair beta support « RIFF Box – JTAG Revolution Ramuwalia |
01-30-2013, 08:01 | #9 (permalink) | |
Member: 745672 Status: Offline Thanks Meter: 555 | Quote:
But Mine Is S8530 ?........ | |
01-30-2013, 09:10 | #10 (permalink) |
No Life Poster Join Date: Dec 2006 Location: yes
Member: 420658 Status: Offline Thanks Meter: 211 | 1. S8530 or S8500 ? I can see from Screenshots and Text you try S8500 DLL... 2. Full Erase is NO good idea... IMEI lost etc... this is why Bootloop at Logo, IMEI is missing... I have also 1 damaged Block... sometimes you could ignore it... Handset handle damaged blocks... 3. For S8500 I work with CMM Script... to upload BL3 as ELF into RAM... Summary. If S8530 then you need S8530 DLL If S8500, then S8500 DLL is correct... Best Regards |
01-30-2013, 14:11 | #11 (permalink) | |
Thanks...dude. SeT on after flash with dump file but still my phone stuck on Logo | |
01-31-2013, 05:09 | #12 (permalink) | |
Member: 420658 Status: Offline Thanks Meter: 211 | Quote:
NV item 550... You can check this out, via Debug Level set in RC2 file... http://forum.gsmhosting.com/vbb/8830891-post36.html I have solved my problem with CMM Script for S8500 + QPST... Not tested on S8530... But you can NOT restore NV area via simple write FULL dump or something similar... Best Regards | |
05-24-2013, 16:22 | #13 (permalink) |
Freak Poster Join Date: May 2011 Location: india
Member: 1574148 Status: Offline Sonork: robingarg23 Thanks Meter: 9 | my 8530 dead handset i connect with riff and Resurrection successful but no response the handset i search many forum they can flash cmm script s8500 but where i find that file? |
