11-13-2013, 15:21 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algérie Age: 43
Member: 570252 Status: Offline Thanks Meter: 207 | need help on T999 Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung T999 V1.0.4716.5824] Connecting to the dead body...OK Detected dead body ID: 0x707910E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
11-16-2013, 15:55 | #4 (permalink) |
No Life Poster Join Date: Jul 2012
Member: 1783314 Status: Offline Sonork: 100.1620532 Thanks Meter: 127 | If the customer said the phone powered off after a call ....it is definitely a hardware problem. But here is FAQ for " ERROR: No response from the RIFF Box " RIFF JTAG Box FAQ - ERROR: No response from the RIFF Box. |
11-16-2013, 16:02 | #5 (permalink) |
Member: 570252 Status: Offline Thanks Meter: 207 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung T999 V1.0.4716.5824] Connecting to the dead body...OK Detected dead body ID: 0x707910E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 20 kHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
