10-28-2011, 20:58 | #3 (permalink) |
Major Poster Join Date: Apr 2010
Member: 1292456 Status: Offline Thanks Meter: 2 | now connected Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.27, JTAG Manager Version: 1.36 Selected Resurrector: [Samsung I9003] Connecting to the dead body...OK Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Model selected: SAMSUNG - Samsung I9003 Detected dead body ID: 0x0B6D602F |
10-29-2011, 10:21 | #6 (permalink) |
Member: 1292456 Status: Offline Thanks Meter: 2 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.27, JTAG Manager Version: 1.36 Selected Resurrector: [Samsung I9003 (via IRAM)] Connecting to the dead body...OK Detected dead body ID: 0x0B6D602F - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is 4 MHz Settings Code: 0x0009000020000000000000000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Read/Write memory failed during H/W Init. read Memory not works |
10-29-2011, 10:50 | #7 (permalink) |
Member: 1292456 Status: Offline Thanks Meter: 2 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.27, JTAG Manager Version: 1.36 Selected Resurrector: [Samsung I9003 (via IRAM)] Connecting to the dead body...OK Detected dead body ID: 0x0B6D602F - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
10-29-2011, 12:42 | #8 (permalink) | |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Quote:
Is this working device or dead ? As for failed booting, check connection and try with lower RTCK sampling ! | |
11-03-2011, 20:44 | #15 (permalink) |
Member: 1292456 Status: Offline Thanks Meter: 2 | **** no Response Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.27, JTAG Manager Version: 1.36 Selected Resurrector: [Samsung I9003 (via IRAM)] Connecting to the dead body...OK Detected dead body ID: 0x0B6D602F - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 200 kHz Settings Code: 0x0003010020000000000000000025 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
