08-25-2013, 04:59 | #3 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1353936 Status: Offline Thanks Meter: 7 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.51 Selected Resurrector: [HTC OneX (PJ8310000) V1.0.4800.54064] Connecting to the dead body...OK Detected dead body ID: 0x406B50E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector... It is stopped like this I think i need test point. Thanks |
08-25-2013, 07:45 | #7 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: Hanoi, Vietnam
Member: 1012390 Status: Offline Thanks Meter: 95 | Quote:
- No need battery, if detect >> try repair - No need usb cable, if detect >> try repair - Or press Resurrection button, the log windows show the line "Establish communication..." >> Now plug-in usb cable immediatly Hope you luck Code: [04/07/2013 15:47:55] [START OPERATION_ID = RESURRECT] [04/07/2013 15:53:38] Open serial port...OK [04/07/2013 15:53:38] Connecting to the RIFF Box...OK [04/07/2013 15:53:38] Firmware Version: 1.35, JTAG Manager Version: 1.49 [04/07/2013 15:53:38] Selected Resurrector: [HTC OneX (PJ8310000) V1.0.4800.54064] [04/07/2013 15:53:38] [04/07/2013 15:53:38] Connecting to the dead body...OK [04/07/2013 15:53:38] Detected dead body ID: 0x406B50E1 - CORRECT! [04/07/2013 15:53:38] Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK [04/07/2013 15:53:38] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [04/07/2013 15:53:38] [04/07/2013 15:53:38] Resurrection sequence started. [04/07/2013 15:53:38] Establish communication with the phone...OK [04/07/2013 15:53:38] Initializing internal hardware configuration...OK [04/07/2013 15:53:38] Uploading resurrector data into memory...OK [04/07/2013 15:53:38] Starting communication with resurrector...OK [04/07/2013 15:53:38] [04/07/2013 15:53:38] Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (MAG2GA, 0x0003A3E00000 Bytes = 14.56 GB) [04/07/2013 15:53:38] Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (MAG2GA, 0x000000200000 Bytes = 2.00 MB) [04/07/2013 15:53:38] [04/07/2013 15:53:38] Flashing the dead body...OK [04/07/2013 15:53:38] Resurrection complete! [04/07/2013 15:53:38] [FINISH OPERATION_ID = RESURRECT] | |
08-26-2013, 06:00 | #8 (permalink) | |
Member: 1353936 Status: Offline Thanks Meter: 7 | Quote:
stuck at Starting communication with resurrector... | |
09-12-2013, 11:42 | #9 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2023667 Status: Offline Thanks Meter: 0 | HTC One X Test Point found yet?? Has anyone found the test point for this HTC One X Yet? I have the AT&T model with the Snapdragon Qualcomm Chip. If you found the test point PLEASE share because i am 2 hours in and still no luck. Please and thank you -- Sam |
