02-28-2013, 00:17 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: root
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | Nexus one not ressurected - 0x22 iīve got here a htc nexus one (pb99100), whose owner claimed it got dead during update, but it doesnīt get download mode, nor can I flash it with riff. connection was resoldered several times to make sure. resurrection finishes succesfully, but sometimes with error 0x22 (didnīt find in faq whatīs that error), and in other operations this error appears a lot. after resurrection phone does not start in download mode (checked main ribbon cable, its ok), and I canīt get to flash a dump on it. resurrection goes fine: Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC Nexus V1.00] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x55BC (512MB) Flashing the dead body...OK Resurrection complete! but if I select to write dump: Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC Nexus V1.00] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 4 MHz] Settings Code: 0x2701000C000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x55BC (512MB) Writting FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: Stopped due to multiple communication errors. Terminating at 0x000001000000 at first i thought it was bad soldering, and resoldered all connection 2 or 3 times, lowered rtck down to 200Hz, tried low tck, but error persists, and Iīm starting to think thereīs something wrong with its hardware, although I didnīt see anything. if was a wiring issue, it wouldnīt complete resurrection with sample at max without errors. this 0x22 occurs in different ad*******, for instance, one time flashed it got error on 0x0000016A0000, but following try it got error in other ad*******, but not this one. iīm trying again to write dump at 1MHz (18% so far), but that error is atacking again, donīt think that will be completed. Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC Nexus V1.00] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Settings Code: 0x27010009000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x55BC (512MB) Writting FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK WARNING: Programming Error (0x24) at 0x0000016C0000. Attempting to Repeat. WARNING: Programming Error (0x24) at 0x0000016C0000 is Ignored. ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK WARNING: Programming Error (0x24) at 0x000002FE0000 is Ignored. ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK br |
