not able to connect samsung s229 i have tried connecting the handset as per s109 pinout but the handset is not getting detected with riff box......and one more pls explian what does point 2 means....in the pinout it is said as TMODE what does TMODE stand for in riff box pinout |
is there no one to respond |
right now the phone has been detected but the below error is showing....pls help Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.23, JTAG Manager Version: 1.32 Selected Resurrector: [Samsung S109] Connecting to the dead body...OK Detected dead body ID: 0x1F0F0F0F - CORRECT! Set I/O Voltage reads as 3.00V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x44): Communication is not established. Terminating. |
Hi check pinouts , cable length etc, s229 fully accessable on Riff wbr lalitg |
brother the dead body is successfully detected with riff box but why the communication error is showing......with the same cable i connect other phones then why is it showing error for this one |
i m really very disappointed with the support that is being provided....is there someone to help me out |
Hi, There is some problem with phone power. Have You tried to use battery + power button ? Maybe charging ways is damaged. |
please provide me the dump file for samsung s229 |
when you connect the handset just connect the tmode point to gnd/ That's all the solution, otherwise your handset flash could be damaged. |
brother the handset is alive....i m just trying to make a dump file so that i can revive my other same model handset which is dead |
Same problem brother with samsung s109. set is ok. logs are same-- Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.23, JTAG Manager Version: 1.32 Selected Resurrector: [Samsung S109] Connecting to the dead body...OK Detected dead body ID: 0x1F0F0F0F - CORRECT! Set I/O Voltage reads as 3.00V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x44): Communication is not established. Terminating. riff team reply please |
Please Check Jtag Connection & T-mode point Short To Gnd |
I m unable to understand "tmode short to gnd" |
