09-15-2011, 08:11 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: <:D-R-E-A-M-S:>
Member: 1312746 Status: Offline Thanks Meter: 766 | Not able to write dump with RIFF Box pls help Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [Haier C3010] Connecting to the dead body...OK Detected dead body ID: 0x200B10E1 - IGNORED! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Settings Code: 0x0900010000800000000000000024 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x22E0 (8MB) Writting FLASH1 memory from 0x0000000000 to 0x00007FFFFF ERROR: Timeout while waiting for DCC Loader response. Trying to recover... Settings Code: 0x0900010000800000000000000024OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover... Settings Code: 0x0900010000800000000000000024OK |
09-15-2011, 08:12 | #2 (permalink) |
Member: 1312746 Status: Offline Thanks Meter: 766 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [Haier C3010] Connecting to the dead body...OK Detected dead body ID: 0x200B10E1 - IGNORED! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Settings Code: 0x0900010000800000000000000024 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x22E0 (8MB) Writting FLASH1 memory from 0x0000000000 to 0x00007FFFFF ERROR: Timeout while waiting for DCC Loader response. Trying to recover... Settings Code: 0x0900010000800000000000000024OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover... Settings Code: 0x0900010000800000000000000024OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover... Settings Code: 0x0900010000800000000000000024OK ERROR: Stopped due to multiple communication errors. Terminating at 0x0000000000 |
09-15-2011, 13:16 | #5 (permalink) |
Member: 1312746 Status: Offline Thanks Meter: 766 | i have a haier c2000 its blinking...i tried to write dump file using dcc section but when I m trying to do so its showing the above error...can you please tell what is the cause behind such error |
09-15-2011, 15:59 | #8 (permalink) |
No Life Poster Join Date: May 2011 Location: india
Member: 1583254 Status: Offline Sonork: 100.1602320 Thanks Meter: 4,792 | Use QSC60XX_L20_D08_NOR.dll Also Press Power button Continue During Dcc Write |
The Following User Says Thank You to M0YAL For This Useful Post: |
09-16-2011, 12:17 | #9 (permalink) |
Member: 1312746 Status: Offline Thanks Meter: 766 | thanks it was completed.... Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [QSC60XX L20 D08] Connecting to the dead body...OK Detected dead body ID: 0x200B10E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x0000010000800000000000000024 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x22E0 (8MB) Writting FLASH1 memory from 0x0000000000 to 0x00007FFFFF ERROR: Timeout while waiting for DCC Loader response. Trying to recover... Settings Code: 0x0000010000800000000000000024OK Completed in 00:02:54.453 (Average Transfer Rate: 46.96 kB/s) |
04-25-2012, 20:48 | #10 (permalink) |
Freak Poster Join Date: Apr 2011 Location: Spain Barcelona
Member: 1558861 Status: Offline Sonork: aftabmiraj15 Thanks Meter: 4 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung I9003 (via IRAM) V1.0.4464.49946] Connecting to the dead body...OK Detected dead body ID: 0x0B6D602F - IGNORED! Set I/O Voltage reads as 2.65V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x6D010000000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) ERROR: Image file size wrong. Main and Spare not correlate in size. pls hilp |
04-25-2012, 20:51 | #11 (permalink) |
Member: 1558861 Status: Offline Sonork: aftabmiraj15 Thanks Meter: 4 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung I9003 (via IRAM) V1.0.4464.49946] Connecting to the dead body...OK Detected dead body ID: 0x0B6D602F - IGNORED! Set I/O Voltage reads as 2.65V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x6D010000000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) ERROR: Image file size wrong. Main and Spare not correlate in size. |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
