11-09-2012, 16:15 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | one v need help i have htc one v , tried to unlock with LGETOOL , phone is dead now , tried resurect it with lgetool , no luck now im trying with riff system is win7 sp1 64bit. riff is installed ,qualcomm hs-usb Qdloader 9008 driver for htc one v is installed , Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.45 Selected Resurrector: [HTC OneV (PK76100) via USB V1.0.4608.58885] Looking for the HS-USB QDLoader Interface...OK Open the HS-USB QDLoader Interface Port...OK Establish connection with the Device...OK Uploading resurrector data into memory...OK Starting communication with resurrector... after last line , it seem riff just stoped (on the battom it say resuractor job finished) but nothing happen , after 30 secs i see windows trying to install driver but geting " unknowen device" and cant seem to install any driver for it if i replug the htc , and start all over , same results. any ideas what drivers its looking for ? and if i need to do anything else ? |
11-09-2012, 16:36 | #2 (permalink) | |
Member: 21937 Status: Offline Thanks Meter: 279 | Quote:
after riff soft countring secs 1/5->5/5 and say done , 30 secs i get unknowen device connected and no drivers | |
11-09-2012, 18:33 | #3 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Replace eMMC, and next time think before using "lgtool". You're not first customer with such problem. |
The Following 2 Users Say Thank You to legija For This Useful Post: |
11-09-2012, 21:50 | #4 (permalink) | |
its your tool im just using it. i dont understand why eMMC killed by unlock try ? and if there is a risk of hardware kill you should state it it lgetool in red in htc unlock try before all instractions...... now why eMMC killed by it if you can explain | |
11-09-2012, 21:58 | #5 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi You Can't "Resurrect".... Because I'm Sure You Didn't disassemble Phone and Use TP..... ***For Resurrect Htc One-V,You need : Quote:
eMMC Killed By Wrong Vol input from sd slot...or other reason Just Try With Test PoinT And Post Result ------------ Hi Mr.Legija Yes,absolutely True... I saw a lot of users with such problem. | |
11-10-2012, 06:18 | #6 (permalink) | |
thanks | |
11-10-2012, 13:53 | #7 (permalink) | |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Quote:
Where You got such idea ? | |
11-11-2012, 08:53 | #9 (permalink) | |
but here is start with tp Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.45 Selected Resurrector: [HTC OneV (PK76100) via USB V1.0.4608.58885] Looking for the HS-USB QDLoader Interface...OK Open the HS-USB QDLoader Interface Port...OK Establish connection with the Device...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0000 (SEM04G, 0x000092400000 Bytes = 2.29 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0000 (SEM04G, 0x000000100000 Bytes = 1.00 MB) Flashing the dead body... ERROR: Timeout while waiting for DCC Loader response. Terminating at 0x00000008D200 i will try few more times | |
11-11-2012, 12:12 | #10 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Yes,This is Correct Step For Resurect Via TP Method -- So,This is fault eMMC Chip and You need replace by new one --------------------------------------- |
05-27-2015, 15:15 | #15 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Chile
Member: 71290 Status: Offline Sonork: 100.1645657 Thanks Meter: 104 | thk Riif Box Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [HTC OneV (PK76100) via USB V1.0.4608.58885] Looking for the HS-USB QDLoader Interface...OK Open the HS-USB QDLoader Interface Port...OK Establish connection with the Device...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0000 (SEM04G, 0x000092400000 Bytes = 2,29 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0000 (SEM04G, 0x000000100000 Bytes = 1,00 MB) Unlocking the Phone...OK Unlock complete! |
