01-31-2014, 15:43 | #1 (permalink) |
No Life Poster Join Date: May 2011
Member: 1576733 Status: Offline Thanks Meter: 622 | Oppo x-907 Is Connected with Riff but.... When I connect Connect and Get ID, then, shows: But, when I press "Analyze JTAG Chain" it shows the following information: I remember that first time it was connected and shows the following id also But, Can not read the Dump. Same as Connect and get ID ( Can Legija bro, give me little bit hint.......so that I can read dump and send dump to analysis Country Lock code Thank you for your help in Anticipation. Diosa |
01-31-2014, 15:55 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | If i remember well, this model don't have RTCK pin marked. So You have to use fixed TCK value. This is log from successful connection: Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC Sensation (PG5811000) V1.0.4711.7] Connecting to the dead body...OK Detected dead body ID: 0x204210E1 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is 1 MHz Settings Code: 0x20010600000000000000000000800000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (KTS00M, 0x0003A3E00000 Bytes = 14.56 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (KTS00M, 0x000000200000 Bytes = 2.00 MB) Reading FLASH1 address space from 0x000000000000 to 0x0000000001FF Completed in 00:00:02.605 (Average Transfer Rate: 805048.75 kB/s) |
01-31-2014, 16:07 | #3 (permalink) | |
Member: 1576733 Status: Offline Thanks Meter: 622 | HI Mr.Legija, Get This Error .... Quote:
BR, Diosa | |
01-31-2014, 16:26 | #6 (permalink) |
No Life Poster Join Date: Jul 2012
Member: 1783314 Status: Offline Sonork: 100.1620532 Thanks Meter: 127 | @Diosa ... look at the Body ID in your Log .... Then look at the Body ID in Legija's Log.... it's the same , in Legija's Log it was " Ignored" So go into "JTAG Manager ---> Advanced settings --->Ignore target ID Code Then try again |
01-31-2014, 16:41 | #8 (permalink) |
Member: 1783314 Status: Offline Sonork: 100.1620532 Thanks Meter: 127 | It is not confusing ....I explain Look at the pinout of the phone in your picture.... do you see RTCK and TCK ? I see only TCK ... so you will use TCK as settings in JTAG manager ...in "drop box" setting use 1Mhz |
02-01-2014, 10:08 | #10 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Earth
Member: 6884 Status: Offline Sonork: 100.1621477 Thanks Meter: 105 | you read not the posting from spagman and dont set the setting's from legija's what he post: Go to Box Service > Advanced settings and check > Ignore target ID Code |
The Following User Says Thank You to Benhure For This Useful Post: |
02-01-2014, 14:59 | #14 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, Please download remote helper from and contact me via ICQ. Read this first: How to request support for unsupported model (Read this first ! ! !) |
The Following User Says Thank You to legija For This Useful Post: |
