02-05-2014, 15:56 | #1 (permalink) |
Junior Member Join Date: Jan 2014 Location: Romania Age: 35
Member: 2117890 Status: Offline Thanks Meter: 0 | orange nivo 7560u hepl not getting in recovery Can't find (flash /flasher ) try to resurrect but i have problems with connecting i tried to adjust manual speed but no luck [2/5/2014 3:57:40 PM] [START OPERATION_ID = GET_DEVICE_ID] [2/5/2014 3:57:41 PM] Open serial port...OK [2/5/2014 3:57:41 PM] Connecting to the RIFF Box...OK [2/5/2014 3:57:41 PM] Firmware Version: 1.37, JTAG Manager Version: 1.55 [2/5/2014 3:57:41 PM] Selected Resurrector: [Orange Nivo 7560U V1.0.5095.49743] [2/5/2014 3:57:41 PM] [2/5/2014 3:57:41 PM] Connecting to the dead body...ERROR [2/5/2014 3:57:41 PM] Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK [2/5/2014 3:57:41 PM] [2/5/2014 3:57:41 PM] ERROR: The RTCK Signal does not respond. [2/5/2014 3:57:41 PM] [FINISH OPERATION_ID = GET_DEVICE_ID] |
02-14-2014, 15:55 | #4 (permalink) |
Freak Poster Join Date: Oct 2008 Location: ROMANIA Age: 35
Member: 888603 Status: Offline Sonork: 100.1641525 Thanks Meter: 40 | Same problem to mine. Have you found any sollution? Connected every way but still "RTCK Signal does not respond" to Orange Nivo... P.S. Stuck in SECBOOT too. |
04-03-2014, 14:26 | #7 (permalink) |
Member: 888603 Status: Offline Sonork: 100.1641525 Thanks Meter: 40 | Phone stuck into SECBOOT again. With Riff I get: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Orange Nivo 7560U V1.0.5196.55950] Connecting to the dead body...OK Detected dead body ID: 0x007700E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x45 Any ideea? P.S. On another clean PC error is same. Riffbox it's working 100% ok with other phones. |
