Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Rocker Team products > RIFFBOX
Old 07-22-2012, 15:36   #1 (permalink)
..::Tabrez khan::..'s Avatar
Member: 1687888
Unhappy P1000 stucks at samsung!!!
Hello evEry body I have 2 Samsung P1000 One of them are DEAD BOOT and one of them is Stucked at samsung Dead boot repaired successfully BY RIFF!!
And second one which one stucked at samsung i tried each and everything on it i reconstructed it!! Sucessfully reconstructted and i tried flashing with several firmwares but still same i posted several posts!!
http://forum.gsmhosting.com/vbb/f606...msung-1469399/
http://forum.gsmhosting.com/vbb/f606...y-tab-1454688/
Tried all of them but still same i need a big help from you guyz im new to riff i bought yesterday only so please give me full procedure it just stucks at samsung!! pLease help me
Br...,
Old 07-22-2012, 17:14   #2 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
wrong help...99.9% it's SW
Flash with latest firmware
Max_B
Old 07-22-2012, 21:08   #3 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Hi
First you need make sure about phone model...... some user have a different type of galaxy tab...like P1000N..P1000L...P100...I800...etc
Then,You Need Flash phone with latest 2.3.3 firmware...Also You Need Use "PIT" File..
p1000 Have a some Pit..So,You Need Check with all "Pit"
If still have a problem, Try This:
1-Erase Full Flash Size By RIFF-Box( It's 512MB)
2-Resurrect phone With Select All Other Option(Germlin-Recovery-Linux Kernel)
3-Flash phone by Odin..(You need 3 parts firmware + P1_add_Hidden.pit)..Don't Forget Checked "Repartition"
4-Repair EFS Content By Riff plugin or ADB Command
Or:
1-Erase full flash size
2-Write Good Working Dump File
3-Repair Imei
Old 07-23-2012, 10:48   #4 (permalink)
Member: 1687888
Originally Posted by BABAK NURI View Post
Hi
Or:
3-Repair Imei
How to erase full flash size 512 MB bro please help me im not expert in this box i bought this box day before yesterday!!
Old 07-23-2012, 23:07   #5 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Hi
You can search on forum
anyway
goto DCC Read/Write page...select auto full flash size,uncheck "main" and Press erase
Old 07-23-2012, 23:48   #6 (permalink)
Member: 1687888
Red face
Hi
anyway
s erase
bro then what about other things Explain all the things sir how to write efs file and where ill get find that file and what about full backup ? i cant find anything please help me sir im really a big noob for this box :-(
Old 07-24-2012, 00:58   #7 (permalink)
mobilefactor's Avatar
Member: 1560569
Bro. No Jtag required to fix this problem ... I can fix it for u... IM me tomorow coz I am on mobile rt now.
Do not care
Gesendet von meinem GT-I9100 mit Tapatalk 2
Old 07-24-2012, 04:30   #8 (permalink)
..::Thanh_gsm::..'s Avatar
Member: 207400
Sonork: 100.1582556
I have this file, fix much P1000 and M180s hang logo after repair boot.
Use odin, choose as PDA and flash.
dbdata.rfs.tar
The Following User Says Thank You to ..::Thanh_gsm::.. For This Useful Post:
Old 07-30-2012, 17:53   #9 (permalink)
Member: 1687888
Unhappy
Hi
anyway
I did each and everything what you have say sir i erased phone i flashed with several firmwares with several pits I erased phone wrote 3 of DUMP file which exist in support area still the damn ****ING phone stucks at samsung i wrote dbdata.tar file also still stuck at this please anyone HELP ME!!! Really stucked at this one!!
Old 07-30-2012, 18:04   #10 (permalink)
Member: 1687888
And i Saw that When ever i solder and connect to RIFF box The CPU Gets heat it self And wen i connect to cable too it will get heat!! Wen its get late it will heat the whole BOARD!! Please help me anyoNE this phone reaLLY *****SSSS!!!!
Old 07-30-2012, 18:06   #11 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
After writing dbdata.rfs.tar of course you must reflash phone normal way !
Means you have to have
- Files : Code, CSC & Modem
- Pgm : Odin3_v1.31.exe, file Odin3.ini & Pit.
- Driver : SAMSUNG_USB_Driver_for_Mobile_Phones_v1.3.400.0.ex e
Settings as on the picture.
Of course Hardware must be good to succeed.
But if we say that your hardware is bad, arrogant people will edit my post again
Max_B
Old 07-30-2012, 18:09   #12 (permalink)
Member: 1687888
Thumbs down
Max_B
yeah i did each and everything AFter dbdata.rfs file i flashed with several firmwares reconstructted MR babak NURI sir helped me a lot !! But still stucked!!
Old 07-30-2012, 18:26   #13 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Personnaly I don't think that overheating CPU could be fixed via software from start.
And all freezing at SAMSUNG logo phones I had were not SW faulty !
SAMSUNG freezed = Hardware fault
However if the blue line stops at initial, then you can try to fix boot.
But if set hanged without having played with, then hw is damaged.
Max_B
Old 07-30-2012, 18:34   #14 (permalink)
Member: 1687888
Add me oN Yahoo messenger sir i need youre help
Old 07-30-2012, 18:49   #15 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Sorry I work and have no much time for forums and IM but I will try
Max_B
SW ASIC MISHATCH at 5110 jonwillow Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-29-2001 15:30
Something special at http://westerna.org westerna GSM Mobile Links 0 09-14-2001 10:29
Just have a look at ... frenchcortex GSM Mobile Links 0 08-06-2001 18:54
How can I use AT command control Nokia6110?Help me! arnom Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-15-2000 07:35
Programmeing tools at www.cellularrepairs.co.uk dave GSM Mobile Links 0 09-09-1999 20:22
Page generated in 2.04420 seconds with 12 queries
