10-13-2012, 10:30 | #1 (permalink) |
Freak Poster Join Date: Aug 2012 Location: Phillippines
Member: 1798740 Status: Offline Sonork: 1621776 Thanks Meter: 12 | P1010 None is detected help,, no promblem w/ battery try charge no luck Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung P1010 V1.00] Connecting to the dead body...FAILED None is detected. also try to set JTAG TCK speed analyzev JTAG Chain ok |
10-13-2012, 11:10 | #3 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Germany/NRW
Member: 936229 Status: Offline Sonork: 1606911 Thanks Meter: 115 | Hi. Create a Magic Card with Riff and put in Device and test again. I think you Device have a HW Problem,not Bootloader. |
The Following User Says Thank You to Pulka For This Useful Post: |
10-14-2012, 03:38 | #9 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | @ oxygen10 Please Check SD OR Use another SD -- For check SD..Please Put SD in SD_Reader...Then Put into PC...if PC Ask you for "Format"..You Have Correct SD_Magic --- Can you contact me via sonork with connected phone to Riff-Box? i can check your phone via remote |
