09-02-2014, 06:13
#1 (permalink)
Member: 774029
Thanks Meter: 5 | p3100 deadboot....need help resurrect complete but still dead....no download mode....pls help riff box team Quote:
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.37, JTAG Manager Version: 1.55
Selected Resurrector: [Samsung P3100 XLoader+ V1.0.4800.44817]
Connecting to the dead body...OK
Detected dead body ID: 0x3BA00477 - CORRECT!
Set I/O Voltage reads as 2.61V, TCK Frequency is 8 MHz
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x0100/0x0015 (M8G2FB, 0x0001D2000000 Bytes = 7.28 GB)
Detected an Initialized FLASH2 Chip, ID: 0x0100/0x0015 (M8G2FB, 0x000000200000 Bytes = 2.00 MB)
Selected Resurrection Data for the eMMC Chip with Capacity = 7.28GB
Flashing the dead body...OK
Resurrection complete!
| i already did this Quote:
21.02.2013 RIFF JTAG – Samsung GT-P3100 Galaxy Tab 2 7.0 Unbrick – Dead boot repair supported
Samsung P3100 is based on the OMAP4430 Processor (Cortex-A9 Dual-Core). JTAG pads are very small; professional experience in soldering is required to connect wires to the JTAG interface.
Please note: The initial loader in the Samsung P3100 is XLOADER. Due to OMAP4430’s some peculiar TrustZone security features current resurrector will boot only in case XLOADER is alive. That’s why model name of current resurrector has additional text: ‘XLoader+’. In case XLOADER is damaged (which happens for example after wrong firmware reflash), you will have to use different resurrector DLL – the one with the ‘XLoader-” delimiter.
To resurrect Samsung P3100:
Solder JTAG cable to Samsung P3100 JTAG pads;
Connect USB cable to phone and PC;
Insert battery;
Make sure Samsung P3100 is selected in the list of models;
Make sure a fixed TCK frequency is selected;
Click Resurrect button;
Wait till software signals a successful operation completion;
Disconnect USB cable, de-solder JTAG wires;
Now phone is in bootable condition, that is, even if it does not start up normally, you can flash it using original Samsung downloader software to restore it to the working state.
To enter download mode:
Disconnect PC cable;
Insert battery;
Hold ‘Volume Down’ key and press Power-On.
