P3100 Restart need help p3100 hang and restart after few second in menu i try factory reset complete but still same. i try flash dith odin falied when go to recovery menu show applied multi-csc applied the CSC-code :xse did not match sized '/system/csc/common/system/csc/feature.xml' ( No Data Available) whats the problem sir |
ressurection u mean ? |
Connecting to the dead body...OK Detected dead body ID: 0x3BA00477 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000043 No Resurrection Data is available for the eMMC Chip with Capacity = 0B WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 7.28GB ERROR: Selected FLASH Chip was not initialized by the DCC Loader whats the problem i use dll file p3100 xloader |
Hi i see in your log,eMMC is damaged....But if you have alive phone,Check Soldered Wires... |
I try ressurector complete .. but still same. Nothing change still did not find csc??? |
applied multi-csc applied the CSC-code :xse did not match sized '/system/csc/common/system/csc/feature.xml' ( No Data Available) whats the problem sir if my emmc damage. i replace with a new one. tell me the procedure to write with riffbox. need solution urgent |
how procedure in riffbox anyone can explain step if i change new emmc for p3100 |
Change eMMC then go to downloading and flash your device... if after you changed emmc and didn't have downloading then you need to resurrect your phone then do the rest... nothing special.. Good Luck ;) |
p3100 applied multi-csc applied the CSC-code :inu did not match sized '/system/csc/common/system/csc/feature.xml' ( No Data Available) whats the problem sir |
experts the tab p3100 is in working condition but the apps cannot be removed or the data cannot be deleted the tab gets restarted every 5 min while reset i get this menu at the bottom applied multi-csc applied the CSC-code :inu did not match sized '/system/csc/common/system/csc/feature.xml' ( No Data Available) any one have solved this fault if yes pls share the solution |
please solusi legija team |
please helpmy sir:confused: |
same problem with p5110 restart and error in csc did not match sized '/system/csc/common/system/csc/others.xml' |
i got S6310 today with the same error did not match sized '/system/csc/common/system/csc/others.xml' (no data available) |
