Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2007 Location: inside Phone
Member: 631496 Status: Offline Sonork: 100.1581341 Thanks Meter: 109 | P3100 Restart i try factory reset complete but still same. i try flash dith odin falied when go to recovery menu show applied multi-csc applied the CSC-code :xse did not match sized '/system/csc/common/system/csc/feature.xml' ( No Data Available) whats the problem sir |
![]() | #2 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008
Member: 757064 Status: Offline Thanks Meter: 205 ![]() | Quote:
![]() | #4 (permalink) |
Member: 631496 Status: Offline Sonork: 100.1581341 Thanks Meter: 109 | Connecting to the dead body...OK Detected dead body ID: 0x3BA00477 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000043 No Resurrection Data is available for the eMMC Chip with Capacity = 0B WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 7.28GB ERROR: Selected FLASH Chip was not initialized by the DCC Loader whats the problem i use dll file p3100 xloader |
![]() | #7 (permalink) | |
Member: 631496 Status: Offline Sonork: 100.1581341 Thanks Meter: 109 | Quote:
applied multi-csc applied the CSC-code :xse did not match sized '/system/csc/common/system/csc/feature.xml' ( No Data Available) whats the problem sir if my emmc damage. i replace with a new one. tell me the procedure to write with riffbox. need solution urgent | |
![]() | #9 (permalink) | |
Insane Poster ![]() ![]() ![]() Join Date: Aug 2012
Member: 1802331 Status: Offline Thanks Meter: 13 | Quote:
Change eMMC then go to downloading and flash your device... if after you changed emmc and didn't have downloading then you need to resurrect your phone then do the rest... nothing special.. Good Luck ![]() | |
![]() | #11 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2014
Member: 2217517 Status: Offline Sonork: 1660095 Thanks Meter: 18 | experts the tab p3100 is in working condition but the apps cannot be removed or the data cannot be deleted the tab gets restarted every 5 min while reset i get this menu at the bottom applied multi-csc applied the CSC-code :inu did not match sized '/system/csc/common/system/csc/feature.xml' ( No Data Available) any one have solved this fault if yes pls share the solution |
![]() | #13 (permalink) | |
Junior Member ![]() Join Date: Jul 2014 Location: SURAKARTA INDONESIA
Member: 2220289 Status: Offline Thanks Meter: 2 ![]() | Quote:
please helpmy sir ![]() | |
