02-16-2015, 21:48 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: IRAN(land of heros) Age: 44
Member: 115172 Status: Offline Thanks Meter: 212 | P5100 detected as OMAP4430,any solution? I got SAMSUNG GALAXY P5100 detected as OMAP4430 while connected via USB(with and without battery).I tried to repair it with some omapflasher but i get the error you see below.Of course i'm not if i'm using correct version of flasher.I tried to do boot repair via molex but seems not to be related.Please help me. Code: » OMAPFlash v4.15 (Aug 12 2011) » -v » Entering parameter file:Targets\Projects\espresso\omap4430hs_1200MHZ.txt at li ne: 1 » -omap 4 » -t 36000 » -p OMAP4430_8G_HS » -2 » chip_download EMMC Targets\Projects\espresso\MLO.hs » chip_download EMMC Targets\Projects\espresso\Sbl.bin » command cold_sw_reset » Leaving parameter file:Targets\Projects\espresso\omap4430hs_1200MHZ.txt » @Targets\Projects\espresso\omap4430hs_1200MHZ.txt » Looking for device (omap usb) » Please turn off device » Please turn on device » Waiting for device (omap usb) » Found device (omap usb) » Requesting ASIC id » AsicId items 05 » AsicId id 01 05 01 44 30 07 04 » AsicId secure_mode 13 02 01 00 » AsicId public_id 12 15 01 DB 73 10 BA E2 F4 40 51 FB 77 CF 40 FE 92 89 B0 5D 1E C6 92 » AsicId root_key_hash 14 21 01 B5 85 AC F1 DD 15 B0 6A 74 81 3B FD DD 6E CD 64 22 7C E4 C9 06 58 C6 5B 4C 53 AC 22 9B 4C 6D C0 » AsicId checksum 15 09 01 9C 66 9A D9 68 2A DC CF » Searching 2nd for: OMAP4430_8G_HS 443007 04 HS » Loading second file Targets\2nd-Downloaders\dnld_startup_omap4_hs_4g_es2.s2.si gned.2nd.hs » Entering parameter file:omapflash2nd.txt at line: 45 » -pheriphalboot_reopen » Reading board configuration file Targets\Configurations\configuration_omap4430 _8g.txt » Reading definition file .\targets\definitions\definitions_omap4.txt » -board_config Targets\Configurations\configuration_omap4430_8g.txt » Leaving parameter file:omapflash2nd.txt » Sending size of second file (0x00006E60 bytes) » Transferring second file to target (0x6E60 bytes) » Closing boot connection » Waiting for device (omap usb) » Found device (omap usb) » Waiting for 2nd » Unknown status message '(???' during peripheral boot (waiting for 2nd) Press any key to continue . . . Z:\OMAPFlash_1229_2ndlast>GOTO __loop » OMAPFlash v4.15 (Aug 12 2011) » -v » Entering parameter file:Targets\Projects\espresso\omap4430hs_1200MHZ.txt at li ne: 1 » -omap 4 » -t 36000 » -p OMAP4430_8G_HS » -2 » chip_download EMMC Targets\Projects\espresso\MLO.hs » chip_download EMMC Targets\Projects\espresso\Sbl.bin » command cold_sw_reset » Leaving parameter file:Targets\Projects\espresso\omap4430hs_1200MHZ.txt » @Targets\Projects\espresso\omap4430hs_1200MHZ.txt » Looking for device (omap usb) » Please turn on device » Waiting for device (omap usb) » Found device (omap usb) » Requesting ASIC id » AsicId items 05 » AsicId id 01 05 01 44 30 07 04 » AsicId secure_mode 13 02 01 00 » AsicId public_id 12 15 01 DB 73 10 BA E2 F4 40 51 FB 77 CF 40 FE 92 89 B0 5D 1E C6 92 » AsicId root_key_hash 14 21 01 B5 85 AC F1 DD 15 B0 6A 74 81 3B FD DD 6E CD 64 22 7C E4 C9 06 58 C6 5B 4C 53 AC 22 9B 4C 6D C0 » AsicId checksum 15 09 01 9C 66 9A D9 68 2A DC CF » Searching 2nd for: OMAP4430_8G_HS 443007 04 HS » Loading second file Targets\2nd-Downloaders\dnld_startup_omap4_hs_4g_es2.s2.si gned.2nd.hs » Entering parameter file:omapflash2nd.txt at line: 45 » -pheriphalboot_reopen » Reading board configuration file Targets\Configurations\configuration_omap4430 _8g.txt » Reading definition file .\targets\definitions\definitions_omap4.txt » -board_config Targets\Configurations\configuration_omap4430_8g.txt » Leaving parameter file:omapflash2nd.txt » Sending size of second file (0x00006E60 bytes) » Transferring second file to target (0x6E60 bytes) » Closing boot connection » Waiting for device (omap usb) » Found device (omap usb) » Waiting for 2nd » Status malformed response (3 bytes) during peripheral boot (waiting for 2nd) Press any key to continue . . . Z:\OMAPFlash_1229_2ndlast>GOTO __loop » OMAPFlash v4.15 (Aug 12 2011) » -v » Entering parameter file:Targets\Projects\espresso\omap4430hs_1200MHZ.txt at li ne: 1 » -omap 4 » -t 36000 » -p OMAP4430_8G_HS » -2 » chip_download EMMC Targets\Projects\espresso\MLO.hs » chip_download EMMC Targets\Projects\espresso\Sbl.bin » command cold_sw_reset » Leaving parameter file:Targets\Projects\espresso\omap4430hs_1200MHZ.txt » @Targets\Projects\espresso\omap4430hs_1200MHZ.txt » Looking for device (omap usb) » Please turn on device » Waiting for device (omap usb) » Found device (omap usb) » Requesting ASIC id » AsicId items 05 » AsicId id 01 05 01 44 30 07 04 » AsicId secure_mode 13 02 01 00 » AsicId public_id 12 15 01 DB 73 10 BA E2 F4 40 51 FB 77 CF 40 FE 92 89 B0 5D 1E C6 92 » AsicId root_key_hash 14 21 01 B5 85 AC F1 DD 15 B0 6A 74 81 3B FD DD 6E CD 64 22 7C E4 C9 06 58 C6 5B 4C 53 AC 22 9B 4C 6D C0 » AsicId checksum 15 09 01 9C 66 9A D9 68 2A DC CF » Searching 2nd for: OMAP4430_8G_HS 443007 04 HS » Loading second file Targets\2nd-Downloaders\dnld_startup_omap4_hs_4g_es2.s2.si gned.2nd.hs » Entering parameter file:omapflash2nd.txt at line: 45 » -pheriphalboot_reopen » Reading board configuration file Targets\Configurations\configuration_omap4430 _8g.txt » Reading definition file .\targets\definitions\definitions_omap4.txt » -board_config Targets\Configurations\configuration_omap4430_8g.txt » Leaving parameter file:omapflash2nd.txt » Sending size of second file (0x00006E60 bytes) » Transferring second file to target (0x6E60 bytes) » Closing boot connection » Waiting for device (omap usb) » Found device (omap usb) » Waiting for 2nd » Unknown status message '?d???d?usb#vid_0451&pid_d00f#5&34472dfd&0&4#{00873fdf- 61a8-11d1-aa5e-00c04fb1728b}?' during peripheral boot (waiting for 2nd) Press any key to continue . . . |
