04-02-2012, 14:04 | #1 (permalink) |
Junior Member Join Date: Apr 2012
Member: 1742749 Status: Offline Thanks Meter: 0 | P6200 Mobo does not maths I've got a Samsung Galaxy Tab 7 Inch GT-P6200. It is bricked. I opened it up and discovered it is not the same as the picture in the JTAG Manager for Roff Box (Version 1.41) The Mobo is the wrong way around. It says GT-P6200_REV0.0 2011.06.20 I'm enclosing some pictures, hope someone can tell me if it is supported and where I need to solder. Thanks ImageShack® - Online Photo and Video Hosting ImageShack® - Online Photo and Video Hosting ImageShack® - Online Photo and Video Hosting |
04-04-2012, 12:12 | #5 (permalink) |
Member: 1742749 Status: Offline Thanks Meter: 0 | I removed the shield, but there is nothing interesting underneath it. When you look at my second picture, you'll see the correct side. In the lower center of the shield there is a gap. It shows 2 connectors. A large one and a small one. The small one 1 a 10 pin connector. This can't be the one, because the one on the official Riff Box picture has 12 pins. On the back side (first picture I uploaded) there is a 12 pin connector. But I'm not sure if this is the one. The backside also had 2 sets of 9 gold plates (easyer to solder to) These plates are very much the same as the model P1000. My best quess is that I should connect here. More help would be nice. |
04-04-2012, 13:46 | #6 (permalink) |
Member: 1742749 Status: Offline Thanks Meter: 0 | SUCCES ! P6200 is Alive I did it. With help from Legija. The 12 pin connector is on the other side of the board. So not the side on the riffbox picture with the processor and all the chips. But on the backside. On the backside there a 2 rows of 9 gold plate squares (maybe rectangles) I soldered to those plates and the P6200 flashed succesfull. I counted the plates 1 2 3 4 5 6 7 8 9 and 10 11 12 13 14 15 16 17 18 Connect wires like this: 1 = GND 2 = TRST 3 = TDO 4 = TCK 5 = TDI 8 = TMS 10 = NRST Then I only connected the USB cable to the pc. So NO battery. Flashed succesful: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.31, JTAG Manager Version: 1.41 Selected Resurrector: [Samsung P6200 V1.0.0.0] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (MAG4FA, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (MAG4FA, 0x000000080000 Bytes = 0.50 MB) Flashing the dead body...OK Resurrection complete! Now I can start the tablet in Download mode again. |
04-05-2012, 09:21 | #8 (permalink) |
Member: 1742749 Status: Offline Thanks Meter: 0 | I'm not out of the woods yet. I'm looking for (odin flashable) roms. First one did not md5 check ok. The second one flashed, but tablet still did not boot. Trying to find out if I should use a 16Gb, 32Gb of 64Gb rom. First going to try P6200XXLB1 I also found P6200JPKK3 - P6200XXKL7-XEUKL1 - P6200XXLA2-OXEKK1 SER - P6200DDKL2-ODD - P6200DXKL3-OLBKK8 XME - P6200ZSKL2-ZZT. Hope something works. |
07-18-2012, 14:33 | #10 (permalink) | |
Cheater -Don't Deal with him- Join Date: Dec 2006 Location: Riyadh saudia
Member: 407564 Status: Offline Thanks Meter: 141 | Quote:
for me i do same bot way ur and rif team pic but failed to connect Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung P6200 V1.0.0.0] Connecting to the dead body...ERROR Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz | |
11-17-2012, 11:20 | #11 (permalink) | |
Freak Poster Join Date: Jun 2008 Location: Bali
Member: 793212 Status: Offline Thanks Meter: 29 | Quote:
i hope everything is ok. i just need to you to send me the pin out samsung tab 7 plus (P6200),coz' i already try many time the pin out such as in the picture of riff jtag but nothing happen,even i have been trying to solder pin out on the other side of PCB (2 rows of 9 gold plate squares ) but stil nothing happen also I 1 2 3 4 5 6 7 8 9 and 10 11 12 13 14 15 16 17 18 Connect wires like this: 1 = GND 2 = TRST 3 = TDO 4 = TCK 5 = TDI 8 = TMS 10 = NRST thanks best regard from bali ,indonesia | |
11-17-2012, 13:50 | #13 (permalink) | |
http://s51.radikal.ru/i131/1211/09/42c052fe47d8.jpg Last edited by BABAK NURI; 11-18-2012 at 11:12. | |
12-10-2012, 19:53 | #15 (permalink) |
Junior Member Join Date: Jul 2012
Member: 1779056 Status: Offline Thanks Meter: 0 | Hello I want to contribute to the subject as well as his support, and that comments made sharky48 pinouts and even with the help of friend found alternative points for the jtag but have not NRST point so we used that time the image that comes in the box riff but does not react the main board does not detect the riff to which it should be |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
Does any one know how to program the ESN number with nokia 6120? | Bert | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-02-1999 10:45 |
DOES THE CELLNET DIGA HACK STILL WORK??? | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-04-1999 13:55 |
