Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 10-25-2012, 20:28   #1 (permalink)
microtel's Avatar
Member: 44395
Thanks Meter: 7
P6800 boot repair, emmc repair...
I done a resurrection on P6800, but with original samsug flasher with pit and with separated boot pda and modem, i got error message in boot write.
What i have to do now? Write a full dump in to tab (where can i get a full dump?) or repair with emmc application but i need a files too, where can i get those files?
Thank you for your help!
Old 10-26-2012, 03:27   #2 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,397
Hi
i haved same problem with you in 2 weeks ago,But i was repaired my tab
Please explain me about phone history,,,,Also tell me,odin give error when writing which file? boot.bin or sbl.bin
i think this is damaged boot rom2 in tab,Also Possible eMMC fault
For First Try,,,Please Search for any firmware without included boot file or sbl
I think this is P6800JPKL4
Also,You can flah phone with another PIT
Can you contact me via sonork?
Old 10-26-2012, 12:38   #3 (permalink)
microtel's Avatar
Member: 44395
Thanks Meter: 7
Thank you for your help i flashed wit the firmware that you prefered with odin, with pit, now iv got this error message from pda s recovery menu
Old 10-26-2012, 12:43   #4 (permalink)
microtel's Avatar
Member: 44395
Thanks Meter: 7
p6800 error mesage
IMAGE LINK
http://tinypic.com/r/2rpu1oj/6
Old 10-26-2012, 13:37   #5 (permalink)
microtel's Avatar
Member: 44395
Thanks Meter: 7
p6800 error pic
Originally Posted by microtel View Post
Thic picture is much better http://i45.tinypic.com/6p7t3b.jpg
Old 10-26-2012, 13:58   #6 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,397
Hi
This is new phone...?(I Mean not second hand???)
Please make both "wipe" ,Then Reboot and wait for 10min....
if phone not startup,Try this:
Use google for find any "CWM.tar" or "CF-Root.tar" or any other ....Then Flash this file via odin
Then,Search for any Stock Rom.zip(I Think ics rom is good idea) and install from recovery menu (both wipe still needed)Then Reboot...
and wait 10 min after Reboot
Old 10-26-2012, 18:07   #7 (permalink)
microtel's Avatar
Member: 44395
Thanks Meter: 7
Sir
I done everything step buy step as you write down, but rom installing from external sd card stucks im waiting about 20 minutes but nothing....
What now?
The Following User Says Thank You to microtel For This Useful Post:
Old 10-27-2012, 01:24   #8 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,397
Hi
Try This:
1-Download officially firmware P6800XXLQ1 or Q2
2-Flash this firmware..but odin give error when flashing "boot.bin or sbl"
3-Don't care error,....Reboot phone and start downloading again
4-open odin and select "CWM-20120710-p6800.tar" in PDA ...or any other compatible kerne(CWM) with ICS....Then,Flash it
5-after done,phone reboot and automatically going to "recovery Menu"
6- download This rom(This is Custom ROM)
P6800XXLQ1_ICS_IT168-CWM.zip
7-i can't remember,phone can load this rom from SD or Internall_memory.....So,You Need Copy into both...Then Try install
Please Note: if you flash done with 3.2 Firmware,You Can't install any Custom Rom based on ICS(4)
For install any ICS Custom Rom,You Need Flash Stock ICS First
Kernel Link : http://dl.xda-developers.com/attachd...0710-p6800.tar
Custom ROM :
http://199.91.153.26/dyj66ep6d1og/a1..._IT168.zip.001
http://199.91.154.43/c7g816wq7hsg/c9..._IT168.zip.002
http://199.91.153.144/supcf25822fg/y..._IT168.zip.003
Old 10-29-2012, 12:53   #9 (permalink)
microtel's Avatar
Member: 44395
Thanks Meter: 7
I done everything step by step + factory reset, clear cache, and dalvik reset
but, instalation process from external sd card hungs up again.
What about full flas with riff, maybe works?
Old 10-30-2012, 05:10   #10 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,397
Hi
You can try....
Please Download dump file from Riff-Tracker,Then Write to Phone
Did you install Custom Rom From My Posted Link...?i did use this file and solved my problem
This rom take 10-15 min for install....Did you wait ?
Old 10-30-2012, 05:28   #11 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,397
Hi Again
I Have Another Idea...
For First,Please Tell Me About .Pit File....Did You Use it?
Anyway,if stock pit can't help ,Please Download Attachment
This is 8 different pit file
You need use one by one(Also With "Repartition" And Without)Also With Any Have Firmware(1 Package and 3parts too)
For Example:
P6800JPKL4...This is 1 package,But i Think it's good
1-select pit-1 + Repartiton + P6800JPKL4
2-select pit-1 + Not Check + P6800JPKL4
3-select pit-2 + Repartition + P6800JPKL4
4-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
16-select pit-8 + Not Check + P6800JPKL4
Please NoteThis is very important) :
if flash done(without fail) but phone hang on samsung logo,,,""" GO TO RECOVERY_3e AND MAKE Both WIPE,,,,Then Reboot""""(don't use CWM)...After reboot wait 5-8 min for startup
The Following User Says Thank You to BABAK NURI For This Useful Post:
Old 10-30-2012, 20:00   #12 (permalink)
Pulka's Avatar
Member: 936229
Sonork: 1606911
Thanks Meter: 114
Hi.
Test my 3 Parts Firmware,flash via ODIN.
and use Hongkong PIT
I had a problem with P6800,can't flash via ODIN,always error in SBL or boot.bin.
I have create with Cygwin a Hongkong Firmware without boot.bin,sbl.bin and successfull repair 2pcs.
Old 10-31-2012, 14:18   #13 (permalink)
microtel's Avatar
Member: 44395
Thanks Meter: 7
Originally Posted by Pulka View Post
Hi.
Hi thanks for your help, flashing was done without errors, but still hung up on samsung logo. i made resets from recovery, and i tried to flash with and without repartioning.
Now i will trie a combination what BABAK NURI prefered.
thanx
Old 10-31-2012, 17:15   #14 (permalink)
Pulka's Avatar
Member: 936229
Sonork: 1606911
Thanks Meter: 114
thanx
Hi.
I think you need change the eMMC Chip.
Old 10-31-2012, 18:46   #15 (permalink)
microtel's Avatar
Member: 44395
Thanks Meter: 7
Originally Posted by BABAK NURI View Post
Hi Again
For Example:
Dear Babak Nuri
Your help was correct, pit4 without repartition was worked and now every thing is ok.
I tried to update to newer version, because tihi firmware is 3.2.
Update was FAILD! again
Now how to update to a newer version???
Page generated in 0.39769 seconds with 8 queries
