12-01-2012, 11:30 | #1 (permalink) |
Junior Member Join Date: Oct 2005
Member: 191578 Status: Offline Thanks Meter: 4 | p7320 resurrect problem Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung P7320 V1.0.4701.57969] Connecting to the dead body...OK Detected dead body ID: 0x106A10E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x45 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung T989 V1.0.4455.18306] Connecting to the dead body...OK Detected dead body ID: 0x106A10E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x040100000000000000000003AB400000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (KYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0000 (KYL00M, 0x000000080000 Bytes = 0.50 MB) see log is it a riff box error or bug in latest fimware? |
12-01-2012, 12:26 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, Please set the RTCK to ~1MHz, and retry. If You still have 0x45 error, check cables. If nothing helps, You can contact me via Sonork, I'll check it. |
11-15-2013, 11:57 | #4 (permalink) |
Junior Member Join Date: Jun 2006 Location: Poland, Olsztyn
Member: 290819 Status: Offline Thanks Meter: 1 | Hello, I trying to fix the bootloader in the P7320 and riff does not work. Rezurektor being installed but tablet does not turn on. method peloza does not work. Is there any other way to fix it? |
