12-11-2013, 16:37 | #1 (permalink) | |
Registered User Join Date: Nov 2007 Location: ID
Member: 624177 Status: Offline Thanks Meter: 23 | Please Help, Huawei U8825-1 resurrection problem Quote:
here is the screenshot thank you in advance | |
12-11-2013, 17:16 | #2 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Friend goes to the flap Box service, Advance Settings and check "Ignore ID Code" |
The Following User Says Thank You to toninhosantos For This Useful Post: |
12-11-2013, 17:26 | #3 (permalink) | |
Member: 624177 Status: Offline Thanks Meter: 23 | Quote:
Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung A837 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x007700E1 - IGNORED! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. | |
12-11-2013, 17:46 | #4 (permalink) |
Member: 624177 Status: Offline Thanks Meter: 23 | == edited == at first reply, wrong resurrector selected resurrection finished completely but i still can not get into bootloader mode or fastboot mode Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Huawei U8825D V1.0.4710.49481] Connecting to the dead body...OK Detected dead body ID: 0x007700E1 - IGNORED! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (SJS00M, 0x0000E9000000 Bytes = 3.64 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (SJS00M, 0x000000100000 Bytes = 1.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 3.64GB Flashing the dead body...OK Resurrection complete! |
