10-05-2012, 23:21 | #1 (permalink) |
Freak Poster Join Date: Feb 2010 Location: Vietnam
Member: 1229161 Status: Offline Sonork: 100.1678008 Thanks Meter: 18 | please help me htc mozart cant up any roms i tried to - Select HTC Mozart - Check pinout - it's same for Trophy (10 pin HTC Standard) - Switch to Useful Plugins TAB - Select "Qualcomm Fullflash Image Processing" - Click "Activate Plugin" - Click "Read Partitions from Device" also w/o tick don't adjust HTC partition.... log: Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.99V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Settings Code: 0x0900000000000000000000000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x66BC (512MB) Reading FLASH1 address space from 0x0000080000 to 0x0000081FFF Completed in 00:00:00.032 (Average Transfer Rate: 65535999.97 kB/s) Detected NAND Page = 0x1000 bytes Detected NAND Block = 0x00040000 bytes Partition Table is found in block: 0x0002 Total quantity of listed partitions: 0x0010 WARNING!!! Many Partitions will not correspond to real ad******* for HTC FullImage files when NAND Block Size is 0x40000 WARNING!!! Image file is too small. It must be increased upto: 0x1000 blocks Detected the HTC Partition. The SIMLOCK Zone is not Found. please advice me what should i do for this??? |
10-06-2012, 02:03 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi For Many Case ,This is HW Problem -- Only have 1 way for check.... Put Phone in freezer for 30 min Then flash with latest RUU if phone accept ruu and start normally,it's HW Problem...Because problem back after few min,when heating phone |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
10-06-2012, 21:57 | #3 (permalink) |
Member: 1229161 Status: Offline Sonork: 100.1678008 Thanks Meter: 18 | thanks for your information, but now on the start-up it's show on the screen like this: BLDR: 1.28.2250 MODEM: N/A then run to the menu very slow and could not use. does someone know what the problem could issue like this pz! |
