05-15-2016, 19:55 | #1 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1140060 Status: Offline Thanks Meter: 8 | please help update firmware failed after update firmware,firstly my box working fine when used beta version, and when use v 1.58 the software asked to update firmware but result failed like this; |
05-15-2016, 21:08 | #2 (permalink) |
No Life Poster Join Date: Nov 2013 Location: World Age: 29
Member: 2058871 Status: Offline Sonork: 100.1664591 Thanks Meter: 206 | check first if you box is on lower port COM "in devices administration" 2- make click on "firmware update" in 1.58 and 1.56 versions |
05-15-2016, 21:34 | #3 (permalink) | |
Member: 1140060 Status: Offline Thanks Meter: 8 | Quote:
when update firmware with 1.56 version it posible server down or maintenance? | |
05-15-2016, 21:59 | #4 (permalink) |
Member: 2058871 Status: Offline Sonork: 100.1664591 Thanks Meter: 206 | To me it's work fine... which is your country? Getting RIFF Box Info...OK RIFF Box Firmware Version: 1.37 Connecting to the Updates Server...OK Downloading new Firmware from Server...OK Setting Update Mode...OK Updating Box's Firmware...OK Restarting box, please wait...OK Firmware Update Completed OK Current Firmware Version: 1.37 |
05-15-2016, 22:09 | #5 (permalink) | |
indonesia sir...3 days ago its worked,,i have try with other connection and vpn but same result | |
05-15-2016, 22:12 | #6 (permalink) |
Member: 2058871 Status: Offline Sonork: 100.1664591 Thanks Meter: 206 | try this of the user jomafi "in some cases when you get the message: getting updates... and nothing happens, stop the action by clicking on STOP. The click on check for Updates again. I had this situation 2 or 3 times. Always stopped and started again and it will work properly. So test it...." |
05-15-2016, 22:14 | #7 (permalink) |
Member: 2058871 Status: Offline Sonork: 100.1664591 Thanks Meter: 206 | or this of the user prabue "uninstal the driver & restart the pc then install the driver after that update firmware i also had this same problem & solved in this way" |
