09-22-2013, 22:10 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: bizerte tunisie Age: 38
Member: 1578225 Status: Online Thanks Meter: 17 | plz help err wraite full dump htc amaze 4g Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.51 Selected Resurrector: [HTC Amaze4G (PH8511000) V1.0.4800.46531] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x106A10E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x240100000000000000000003AB400000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (KYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (KYL00M, 0x000000080000 Bytes = 0.50 MB) ERROR: Main data file size is less than requested to flash to main. |
09-22-2013, 23:47 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please Follow This: 1-Uncheck "Auto Full Flash Size" 2-Unchek "Image File is Used" 3-Select Size in "Data Lenght" same as Your Dump Size Or Which Size You Want 4-Press "Write" Thanks |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
09-23-2013, 09:00 | #4 (permalink) | |
Member: 1578225 Status: Online Thanks Meter: 17 | Quote:
after write full dump in size 0x000020000000 0x000020000000 phone no power on | |
