Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006
Member: 391664 Status: Offline Sonork: 100.1580390 Thanks: 228
| Points/Wires info Name Function Connections VCC Power - Supplies VCC (5 V, 10 mA, typically) to the cable. To target system VCC GND Ground - Supplies ground reference to the cable. To target system ground TCK Test Clock - Drives the test logic for all devices on a JTAG chain. Connect to system TCK pin. TDO Test Data Output - data from the target system is read at this pin. Connect to system TDO pin. TDI Test Data Input - this signal is used to transmit serial test instructions and data. Connect to system TDI pin. TMS Test Mode Select - this signal is decoded by the JTAG state machine to control test operations. Connect to system TMS pin. Note TRST is an optional pin in the JTAG (IEEE 1149.1) specification, and is not used by XC9500 CPLDs. If any of your non-Xilinx parts have a TRST pin, the pin should be connected to VCC. Bye ![]() UMER |
| The Following 5 Users Say Thank You to maplegsm For This Useful Post: |
| | #2 (permalink) | |
| Junior Member Join Date: Dec 2005 Location: Planet Earth, near Sun, 3rd Age: 34
Member: 209129 Status: Offline Thanks: 4
| Quote:
DO NOT CONNECT POWER TO YOUR TARGET BOARD USING VCC PIN. IT IS MOST LIKELY YOU WILL KILL THE DEVICE!!! VCC is used by most JTAG devices to adjust their I/O voltage levels to target ones. It has nothing to do with JTAG device power supply, it only powers logic translation buffer chip. Most often JTAG logic voltage levels are 1.8V, 2.6V and 3.3V RIFFBOX does not require this signal to be connected. It uses internal DAC to setup JTAG I/O voltage as required. | |
| The Following 2 Users Say Thank You to Albun For This Useful Post: |
| | #3 (permalink) | |
| Quote:
I Think You are Thinking That 5V Will Kill The Set , I Think NotIf Riffbox Does not Requires This Signal Than Moderators Will Edit Info Bye ![]() UMER | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Please send info | azza69 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 11-11-2000 14:19 |
| I need info doc to make scripts for send.exe ThanksĦĦ | Bolo | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 04-09-2000 11:49 |
| Please info unlock 6150v517 | cIVIc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-27-1999 20:11 |
| Please info unlock 6150 v5.17 | cIVIc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 11-01-1999 02:13 |
| Need info for unliocking 2 lock (with pic microprocesors) | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 06-26-1999 01:00 |
