10-30-2010, 14:44 | #154 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 2.99V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x002C/0x00BA (256MB) Flashing the dead body...OK Resurrection complete! |
11-02-2010, 09:56 | #156 (permalink) |
Freak Poster Join Date: Nov 2007 Location: INDIA
Member: 624348 Status: Offline Sonork: 100.1589208 Thanks Meter: 39 | i897 repaired successful ...thanks to legija Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.15, JTAG Manager Version: 1.19 Selected Resurrector: [Samsung I897] Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x0050 (512MB) Writting FLASH1 memory from 0x00A80000 to 0x00BBFFFF Completed in 00:00:05.562 (Average Transfer Rate: 237.32 kB/s) |
11-02-2010, 16:44 | #157 (permalink) |
Freak Poster Join Date: Mar 2007 Location: _-_-_-_-____---___---____---
Member: 459407 Status: Offline Sonork: 100.110689 Thanks Meter: 164 | i8910& S3370 done by riffbox Great project from rocker team |
The Following User Says Thank You to .:Mahmoud El-masy:. For This Useful Post: |
11-02-2010, 18:03 | #159 (permalink) |
Product Supporter Join Date: Jul 2008 Location: iran-shiraz
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Repaired Successfully -22- i9000 With RIFF BOX Repaired Successfully -22- i9000 With RIFF BOX |
The Following User Says Thank You to dr_moosavi For This Useful Post: |
11-03-2010, 01:23 | #160 (permalink) |
Freak Poster Join Date: Jan 2010
Member: 1208833 Status: Offline Sonork: 100.1590402 Thanks Meter: 142 | HTC RhodiumW resurrected Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.15, JTAG Manager Version: 1.19 Selected Resurrector: [HTC Rhodium W] Connecting to the dead body...OK Detected dead body ID: 0x301000E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x55BC (512MB) Flashing the dead body...OK Resurrection complete! |
11-03-2010, 13:23 | #161 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | elf resurrected and back to life Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.15, JTAG Manager Version: 1.19 Selected Resurrector: [HTC Elf] Connecting to the dead body...OK Detected dead body ID: 0x0692602F - CORRECT! Set I/O Voltage reads as 3.28V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected a Not Initialized FLASH1 Chip ID: 0x4833/0xB7CC (512MB) Preparing to upload USB Downloader...OK Uploading the USB Downloader code ...OK Resurrection complete! |
The Following 2 Users Say Thank You to deepakgarg For This Useful Post: |
11-03-2010, 17:00 | #162 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Skopje, Macedonia Age: 36
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.15, JTAG Manager Version: 1.19 Selected Resurrector: [HTC HD2 (Leo)] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x55B3 (1024MB) Unlocking the Phone...OK Unlock complete! |
11-03-2010, 23:15 | #163 (permalink) |
Freak Poster Join Date: Mar 2007 Location: COLOMBIAA
Member: 459220 Status: Offline Sonork: 100.1590597 Thanks Meter: 85 | IXXX REBUILD Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.15, JTAG Manager Version: 1.19 Selected Resurrector: [HTC Diamond] Connecting to the dead body...OK Detected dead body ID: 0xA01700E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x15AA (256MB) Flashing the dead body...OK Resurrection complete! |
The Following User Says Thank You to GAMMAHIGH For This Useful Post: |
11-04-2010, 00:29 | #164 (permalink) |
Member: 459220 Status: Offline Sonork: 100.1590597 Thanks Meter: 85 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.15, JTAG Manager Version: 1.19 Selected Resurrector: [Samsung i900 PDA] Connecting to the dead body...OK Detected dead body ID: 0x2E649013 - CORRECT! Set I/O Voltage reads as 3.30V, TCK Frequency is 9 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x0040 (256MB) Flashing the dead body...OK Resurrection complete! |
11-04-2010, 18:16 | #165 (permalink) |
Registered User Join Date: Sep 2007 Location: RO, Bucuresti
Member: 595504 Status: Offline Sonork: 100.1580419 Thanks Meter: 249 | HTC HD 2 LEO SUCCES REPAIR Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.15, JTAG Manager Version: 1.19 Selected Resurrector: [HTC HD2 (Leo)] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00AD/0x55BC (512MB) Flashing the dead body...OK Resurrection complete! |
The Following User Says Thank You to ServiceTEL For This Useful Post: |
