01-04-2012, 18:25 | #1 (permalink) |
Major Poster Join Date: Apr 2008
Member: 760708 Status: Offline Sonork: kimiyagostar_ali Thanks Meter: 31 | problem to jtag i9103 Connecting to the RIFF Box...OK Firmware Version: 1.30, JTAG Manager Version: 1.38 Selected Resurrector: [Samsung I9103] Connecting to the dead body...OK Detected dead body ID: 0x4F1F0F0F - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
02-02-2012, 08:05 | #8 (permalink) |
No Life Poster Join Date: Nov 2008 Location: UAE
Member: 890592 Status: Offline Sonork: 100.1581951 Thanks Meter: 4,429 | i have 2 i9103 one is same and other is detecting while i click 'Analyze JTAG Chain' button i dont know whats the problem bt looking for another update from RIFF. WBR Delower |
The Following User Says Thank You to delower10 For This Useful Post: |
04-22-2013, 16:21 | #9 (permalink) |
Major Poster Join Date: Jun 2007 Location: india Age: 45
Member: 528183 Status: Offline Thanks Meter: 7 | Still same problum , supporter plz help very confuse Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung I9103 V1.00] Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is 1 MHz Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x4BA00477, IR Length = 0x04 bits Device on TAP #1: ID = 0x4F1F0F0F, IR Length = 0x04 bits Total IR length: 0x0008 bits Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung I9103 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x4F1F0F0F - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
04-22-2013, 23:47 | #10 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please check soldered Wires....(Also Check GND) --- and: RIFF JTAG Box FAQ - ERROR: RAM memory selftest failed. |
04-22-2013, 23:50 | #11 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Skopje , Macedonia Age: 40
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks Meter: 117 | i think it is better to use charger instead of usb cable , try it some usb ports sometimes doesn't have enough power to give to phones |
04-23-2013, 09:47 | #12 (permalink) |
Member: 528183 Status: Offline Thanks Meter: 7 | thnks for reply sir every time connect add id are showing info every time Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9103 V1.00] Connecting to the dead body...OK Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Detected dead body ID: 0x4F1F0F0F but on click resurrication............. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9103 V1.00] Restarting target (nRST Low then High)...OK Connecting to the dead body...FAILED None is detected. |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
