08-07-2013, 09:15 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Germany
Member: 396421 Status: Offline Thanks Meter: 87 | Product: RF IC Chip and to fix this problem the only way is to change the RF IC Chip. problem is, where to find this chip. I have found some website, and i would like to know, if this is the RF IC Chip we would need to replace the broken one. The Link to product is here: Samsung i9100 RF icPMB5712 :: Samsung :: Charge IC :: Onboard Connectors and IC's :: Mobile Phone Spare Parts :: Gultek Limited or here Samsung i9100 RF ic Also i would like to know if the memory chip is the so called eMMC Chip?! thank you and best regards, huzein |
08-07-2013, 09:59 | #2 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Brisbane, Australia
Member: 1788854 Status: Offline Sonork: Mobile Fix Simple Thanks Meter: 16 | Hi mate, have you tried to recovery the efs with JTAG? You can find the files and steps in this forum. I have fixed many double null issue with it. If it works, say thank you to Master Legija. Cheers. |
08-08-2013, 07:44 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Imei null and Baseband Unknown Problem Come From Few Reason... 1-Sw,,,need reset efs,recreate efs partition or write by Jtag 2-HW.Need replace RF Chip,Also Baseband processor Or Some Regolator Also For Some Case Need Replace eMMC -- But,Please Don't More Ask Because There is no HW Section,You Can Post Only if You have any problem with RIFF box |
08-09-2013, 11:29 | #5 (permalink) |
Member: 396421 Status: Offline Thanks Meter: 87 | @BABAK_NURI as you know, there are plenty of tools, such as NSPro, Z3x etc, with which you can restore EFS and so on. Is there a difference between the methods used in the RIFF Box? If software solution, like from NSPro or Z3x, is not successfull, is there a chance to have success with RIFF Box? or in other words: Where are the differences in the solution from RIFF in comparisn to the software solution? BR |
The Following User Says Thank You to huzein For This Useful Post: |
08-10-2013, 07:53 | #6 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi usually no,all used method is same In fact , Different methods but same result... --- |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
