01-04-2012, 08:41 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: UAE
Member: 890592 Status: Offline Sonork: 100.1581951 Thanks Meter: 4,429 | Programming Error (0x25) is it HW? Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VYL00M, 0x03AB400000 Bytes) Flashing the dead body... WARNING: Programming Error (0x25) at 0x0000000000 is handled as Cut Excess. ERROR: DCC Loader has reported Error Code = 0x3E (0x007FFF <> 0x040000) |
04-29-2012, 14:21 | #2 (permalink) | |
Major Poster Join Date: Dec 2011 Location: Sofia, Bulgaria
Member: 1705542 Status: Offline Thanks Meter: 10 | Almost same here: Quote:
04-29-2012, 22:14 | #3 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi .................................. Quote:
The Following User Says Thank You to BABAK NURI For This Useful Post: |
04-30-2012, 12:20 | #4 (permalink) |
Member: 1705542 Status: Offline Thanks Meter: 10 | OK, but error 0x25 refers to Error Code 0x24. I already tried both Cut Excess and Overlap with Ignore set to react on Error during Flash Write, results in same respond by JTAG Manager (even different TCK Frequencies). |
04-30-2012, 12:32 | #5 (permalink) | |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Quote:
DCC Loader reports that there is bad block at specific address. Bad blocks are unrepairable, but can be skipped and device can function normally up to some percent of bad blocks. With eMMC memory chips, things are different. eMMC contains it's own controller, and problem You have comes as response from controller it self. This error in irrepairable, and You need to replace eMMC chip with working one. | |
The Following User Says Thank You to legija For This Useful Post: |
04-30-2012, 14:04 | #6 (permalink) | |
Member: 1705542 Status: Offline Thanks Meter: 10 | Quote:
Best Regards | |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
Upload / Download eeprom program for 51xx/61xx | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-07-1999 14:03 |
